  #11
Old 06-20-2016, 01:17 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
I use MK319s a lot in various things. Two observations:
* The K in "MK319" is for Kountersunk. That makes them hard to grip.
* The M in "MK319" is for Monel, an alloy of copper and nickel that is harder to drill than aluminum.
My process is generally to use a pin punch to knock the stem through the center. Then I drill #34 into (but not through) the head and break it off as if removing an AN426. If it spins, I'll try holding the edge with a chisel or screwdriver while drilling.
Thanks, Bob K.
Old 06-20-2016, 03:00 PM
sblack sblack is offline
Hi Bob,
Once you've popped off the head, how do you get the shank out?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 06-20-2016, 03:08 PM
airguy's Avatar
airguy airguy is offline
Originally Posted by BillL View Post
The drill bit wants to snag in the hole with sharp edges, so I have held the drill bit at an angle to cut the edges without applying torque to the rivet. It is rough but seems to work at times.
This is my technique as well for spinning rivets. Not ideal, but it works.
Old 06-20-2016, 03:19 PM
Originally Posted by sblack View Post
Hi Bob,
I usually just push them in with the shank of a #34 drill bit.
Old 06-20-2016, 06:04 PM
wfinnell wfinnell is offline
Default Super Glue
I have had good luck with super glue. If you can get it to wick in around the rivet it will usually hold it good enough to drill out. When I drill them out, I try to use a very high speed and very little pressure.
Good luck,
Bill Finnell
RV-8 Fuselage
Tucson AZ
Old 06-21-2016, 04:59 AM
phapp phapp is offline
Default Tool and EAA Video
Blind Rivet Tool
https://www.aircraft-tool.com/shop/d...ODUCT_ID=1341S
EAA Video
http://www.eaavideo.org/video.aspx?v=3256734008001
2019 - 2020 Dues Paid
N423PH Schweizer 1-23 (Sold)
N83881 Champ 7AC
N446PH RV8 (reserved)
PA-25 Pawnee Glider Tow Pilot (volunteer)
CallAir A-9 Glider Tow Pilot (volunteer)
