  #11
Old 01-03-2007, 09:06 AM
apatti apatti is offline
Originally Posted by cjensen
Tony,
I didn't ask for mine with a 30 degree slant, Dean just did it for me. If you don't already have one, just ask that the slant be cut in to it when you order it.
Thanks, Chad. I just called and left a message for Dean.
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
Old 01-03-2007, 10:31 AM
captainron's Avatar
captainron captainron is offline
Default Angle cut
I got my bar from Dean, and after doing an exhaustive computer modeling study
of the angles the bar would have to reach, knuckle clearance while holding the bar, amount of mass at the rivet bucking point vs. loss of mass due to offset, I arrived at the optimal angle of 9 degrees 45 minutes, or 9 3/4 degrees!
(Actually, I just held it against the disc grinder and used the TLAR method!)
I think that 30 degrees moves the mass too far offset from where it's needed, JMHO.
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 01-03-2007, 10:38 AM
brian's Avatar
brian brian is offline
I like the idea of the 30 degree slant. Where is this on the Grov-Air website? I couldn't find it.
It is apparently not listed there. I emailed them and got this reply:
Yes we have them in stock. They are $130.00. They are 4? long x 5/8? thick x 1? wide. These dimensions allow you to use this bar in almost any area. Let me know if you?d like me to send you one or if you live near enough to come by the shop to pick it up.
So, I guess you'd have to call them to order it. However, I had already ordered the one from buckingbar.net, which is same size, $120, and has "a slight angle on one end of the bar".
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
Old 01-03-2007, 11:37 AM
mdredmond mdredmond is offline
I'm sold. I just ordered one from Dean.
Matt Redmond
Denton, TX (KDTO) - VAF #510
Got the Bug & Wife's Signoff
RV-9 Tip-Up, Empennage & Wing
Old 01-03-2007, 11:48 AM
grantcarruthers's Avatar
grantcarruthers grantcarruthers is offline
I have one and don't forsee using any of the bars that came in my tool kit, ever. Period. End of story!!
I did a build class with Troy (Grov-Air) and then had him assist with the first 35 hours or so on my HS etc. I bought a bar from him based on the class experience before even starting my kit.
Expensive yes, but worth it.
No angles on mine yet, bring on the grinder!!
Old 01-03-2007, 02:10 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
I've drank the tungsten kool-aide too. Three rivets was all it took for all my skeptisim to transform into riveting nirvana.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 01-04-2007, 05:27 AM
tomcostanza tomcostanza is offline
You probably ground off an amount worth more than all my bars combined!
Tom Costanza
RV-7A Fuse
Old 01-05-2007, 12:15 PM
Fearless's Avatar
Fearless Fearless is offline
Default Add me to the tungsten list
Dean at Webster Tools returned my call today about a bar. I already have a check on its way to him so he is sending me out a bar today. He said that the bars now have a 10 degree angle on them due to everyones feedback about adding an angle.
I'm still having difficulty with finding the right bar to help me set rivets properly so hopefully this bar will be what I need to get over the hump toward excellence.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 01-05-2007, 03:26 PM
I feel like I am in the middle on an infomercial.
Mine shipped today, too. Once it arrives, I expect to just point it at the rivet I want bucked and "Voila"!
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
Old 01-05-2007, 11:51 PM
Default tungsten bar
A while back, I was bucking in the uppermost part of my rudder, Not a lot of room, really cramped for space. I had my smallest bar in there and beat up my skins (was not a happy camper). I got a sweet deal on Ebay for a .80"x.80" x 2" tungsten bar. I've been using it for weeks now and for bucking in tighter areas there is nothing like it. It weighs a little more that twice what my smallest steel bucking bar weighs. The tungsten bar is less than half the size of my smallest steel bar. For bucking rivets in wide open areas I still like the comfort and control of a larger bar. ymmv
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
