Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #21
Old 06-17-2016, 05:38 PM
N402RH's Avatar
N402RH N402RH is offline
If you are ever in Portland Oregon and would like to try both units with a person that has lots of experience with both of them give me a call. We are located about 5 miles from Van's and have both an IFD540 and GTN650 in my personal RV-10.
End user firmware updates
Avidyne has always made every IFD540 firmware upgrade available to end customers at no charge.
User defined holds
Avidyne has always had it in the IFD540.
Ability to fly radius to fix type approaches
While the IFD540 has the accuracy to fly RF approaches, the bigger issue is that RF approaches require the pilot, aircraft and FMS to be certified to fly RF approaches. Recently Garmin added support for RNAV approaches with RF Legs, but it still has a bunch of caveats: https://bruceair.wordpress.com/2016/...s-and-rf-legs/
Ability to load another approach while flying a missed approach segment
Avidyne has always had this available on the IFD540, you can load many more than two approaches.
Dynamic curved flight plan segments based on speed
The IFD540 supports this
Animated NEXRAD for those that have weather receivers
The IFD540 does not currently support this.
Real time fuel range rings
Avidyne has always had fuel range rings on the IFD540.
LPV+V support
Avidyne added LP + V support to the IFD in July 2015.
Advanced airway navigation including preview capability
The IFD540 has always had procedure preview that actually lets you see the preview before you load the plan, not after the flight plan has been loaded.
Remote control/integration capabilities
Avidyne and Dynon/Advanced Flight Systems have and will continue to work together to create better system integrations. If you have noticed already, the AF-5000 EFIS has the same flight plan coloring as the IFD540. The IFD540 also has a number of remote control features with the remote Bluetooth Keyboard that are very useful.
Rob Hickman
Advanced Flight Systems Inc.
N402RH RV-10
Old 06-17-2016, 07:03 PM
vic syracuse vic syracuse is offline
Super Moderator
What makes the world go around is that we all don't like the same thing.
That being said, yes I did an article for KP regarding these 2 units. When I wrote it the Avidyne unit was much fartehr ahead in capabilities than the GTN series, by a long shot. However, since then, Garmin has come out with another s/w release which is almost on par with the IFD series. But, I certianly enjoyed having the features onthe IFD for quite a while before they were available on the GTN. I do get to install and flight test both the Avidyne and the Gamrin series. They are both very powerful in their own ways. I still find the IFD series much more user friendly when in flight due to the dedicated front panel keys, as opposed to having to hit HOME or BACK to get to the same functions in the GTN series. Yes, one can point out that the GTN has more display real estate, but quite honestly, after I load a flight plan I am never really looking at the GPS. There is so much more information available on the EFIS screens these days. I could see how the larger screen of the GTN series would be an advantage to someone who doesn't have EFIS.
It's also cool on the IFD to see it capture the VOR's along the route and display ID, radial, and distance.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 10-10-2016, 08:14 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Quick update on this topic - I bought an IFD540 from Stein along with some other bits to go in the panel. I also picked up a TAWS annunciator from eBay, since the IFD540 has support for FLTA built in. Really looking forward to getting it installed in the next several months, but gonna keep flying until it gets cold before taking the plane offline.
Incidentally, later mods of the MidContinent MD41-1208 annunciator can be found on eBay for $40 (that's what I paid for mine). Although it's marked as a 28v unit, it functioned absolutely fine on the bench at 14v - in fact it was still visibile/operational down to under 10v.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 11-28-2016, 01:42 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Avidyne IFD440
Stein has a very good trade-in deal on the Garmin 430W for the IFD440 going on right now which I am seriously considering. I wonder if anyone who has experience with the Blue Tooth/WiFi module and the external keyboard would chime in here and tell us if this is a worth while option @ $900.00
I use the iPad Mini with FltPlan Go and I understand that the IFD440 will communicate with this flight planning App.
Any and all thoughts and suggestions are appreciated. Thx.
Ivan Kristensen
Guelph, ON. Canada
RV-10 (C-GMDV) 1355hrs.
Dual GRT 8.4" HXr EFIS, VP-200, TT A/P, Avidyne IFD440, uAvionixX ADS-B out, Sky Radar WX and Traffic, Dual EI's (one Lightspeed & one SDS CPI)
RV-14A under construction.
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 11-29-2016, 06:28 PM
jrouault's Avatar
jrouault jrouault is offline
Default Another IFD wifi point of consideration...
I just did the trade-in of my 430W for the IFD440 and will be getting the wifi option because i am looking forward to the IFD100. The IFD100 is a free app for your ipad to that will let you see and control everything on your IFD400 in a much larger format.
Jason Rouault
RV-7A TMX IO-360 3-Blade MT CS Prop, Flying
Fort Collins, CO
http://www.rouault.us
Old 01-09-2017, 08:24 PM
dvalle dvalle is offline
Default Your KX buyer
Hi Brad
Pretty sure we communicated on this forum but can't recall why?:-)
Dan
Old 03-14-2018, 03:42 PM
Lan Vinh Do's Avatar
Lan Vinh Do Lan Vinh Do is offline
Default Ifd 100 jeppessen subscription needed? For the ifd440 I AM CONFUSED
I just received my IFD440 yesterday and havent installed it yet. I have hard time understand if i need additional subscription with jeppesen to use the ifd100 to enter the flight plan in the IFD440. ( i dont need the approach plate on my ipad. Just need to be able to use the ipad IFD100 app to enter my flight plant etc and not using the touch screen of the IFD440. )
Anybody know that. When i email jeppessen, they want me to buy a MDF subscription and say to me that it doesn?t work with the ifd 440. I need a ifd540. They don?t seem to know what i mean when i talk about the ifd100 app
Thank you
Lan Vinh Do
RV-7A c-GOSV sold
RV-10 C-GMCE
Rv-7 emp completed but waiting boys to be older to help
donation 2020 done ( little bit earlyer)
Old 03-14-2018, 03:52 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default You do not
Anybody know that. When i email jeppessen, they want me to buy a MDF subscription and say to me that it doesn’t work with the ifd 440. I need a ifd540. They don’t seem to know what i mean when i talk about the ifd100 app
Thank you
I just went through this with my new 440. Just bought the Navigation data subscription for the 440. When you start up the IFD100 app, it gives you the opportunity to log in to your Jeppesen account. When you do, you will see your subscription databases. Just select the appropriate one, check it and download it into to app. Easy Peasy. No extra money. Just call them on the phone. The guy I dealt with had to check to make sure how it all worked.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 03-14-2018, 04:04 PM
Default Ifd 100
Thank you Dan. That what i wa thinking
Lan Vinh Do
Lan Vinh Do
RV-7A c-GOSV sold
RV-10 C-GMCE
