Go Back   VAF Forums > Model Specific > RV-4
Old 06-13-2016, 05:41 PM
NorthernRV4's Avatar
NorthernRV4 NorthernRV4 is offline
Default Aileron bellcrank rib
I'm wondering how other builders have dealt with this problem. Two of the rivets that attach the 3/4 angle are located right on the flanged ring around the second lightening hole. This is as per the plans but this leaves a gap between the angle and the rib web. Unfortunately I didn't notice this until I had started riveting.
Port aileron bellcrank rib by James Soutar, on Flickr
I'd like to flatten this area to the angle with a pair of flat sets and my squeezer by I don't think it will lay tightly to the angle. I'd rather not have to drill out the rivets to disassemble it. Any suggestions?
Old 06-13-2016, 06:04 PM
HFS HFS is offline
Default Aileron Bellcrank Rib
Van's original plan was just to rivet through the lightening hole reinforcement and take whatever the result was.
I backfilled the affected areas with Devcon "Liquid Aluminum" or 3M 2216 Scotchweld w/aluminum powder as a thickening agent. After the proper curing interval, I riveted the joint as indicated. Three airplanes, and 2500 hours later - no problems.
David Howe
Old 06-13-2016, 07:23 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Be careful of that bolt shown on the right of your plans picture.
By the time you add in the thin, small diameter washers now called out for that location the bolt end can hit the angle if the tolerances stack up the wrong way.
Check you have a reasonable clearance here when the control rod to the stick is installed - contact, especially under G loads, would be a major control limiter and disaster.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-14-2016, 05:51 AM
David Howe
I'm surprised at that when so many other seemingly small details are fussed over. Being that this is an important structural part to the control system I want to make sure it's the best it can be. I think I'll try and make some conformal shims to fill in the gap. On a related note I was surprised there was not a second 3/4x.063 angle at the other end near the main spar. I considered that for a while and then resolved myself to the fact there are many -4 and -6 flying with no issues.
Old 06-14-2016, 06:50 AM
HFS HFS is offline
You have to remember the time frame for the design/construction of the prototype of this aircraft - it was finished in August of 1979. Van was more interested in simple construction techniques that could be used by most builders - back then there were very few "repeat" builders, so the cumulative skill set was not been developed as well as it is now.
You are building a dinosaur in comparison to the kits available today - almost all of the decisions concerning the health and well being of the construction is up to you. You build the jigs, locate all holes, deal with the inconsistencies of the plans, interpret the plans (as best you can), and all the other things that go along with these early models - early -6's are a lot the same re/building issues.
As John Harmon used to say, "Read the manual, throw it away, build the airplane".
HFS
Old 06-14-2016, 07:38 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Are there three rivets on each horizontal angle?
Hello,
Just looked at the plans in your photo ... are there three rivets in the horizontal angle? One inbetween those which have a clecos inside?
Regards, Dominik
Old 06-14-2016, 12:32 PM
Christopher Murphy Christopher Murphy is offline
Default Rivet it flat
Rivet it flat and make sure it dosent interfere. The integrity of the ring is transfered to the angle. Dont fool with a shim. Meaningless there.
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 06-17-2016, 06:01 AM
Originally Posted by swisseagle View Post
Hello,
Regards, Dominik
There are four rivets in the horizontal angle, two at one end, and two slightly further spaced at the other end. The aft most rivets attach to the vertical angle and the rib and are the ones drilled through the embossed ring.
Aileron bellcrank rib by James Soutar, on Flickr
DWG-16a by James Soutar, on Flickr
Old 06-17-2016, 04:27 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
I'd suggest adjusting the embossed ring using the percussive inertial tuning implement sometimes referred to as a "hammer."
Old 06-17-2016, 04:43 PM
krw5927 krw5927 is offline
What about these two?
Kurt W.
RV9A
FLYING!!!
