The parts are the same as they have always been.
Notches are used in some locations on parts where the radius is tight enough that the part would not form well. This is usually near the leading edge of wing and stabilizer ribs, and tight radius areas of the fuselage bulkheads.
Any other areas of the parts that have any radius in them still typically require some amount of fluting.
A much better check for someone with little experience is to first adjust the bend angle of the flanges and then use a flexible straight edge to check the alignment of the pre-punched holes. Flute as needed until all of the holes align.
Scott McDaniels
Hubbard, Oregon
