Originally Posted by GalinHdz
Exactly.
File for your reservation code, for an experimental aircraft you are an authorized installer so install it yourself, it is a new transponder so you have to get the installation checked for correct code/altitude/power outupt, fly with the unit operating to get an FAA compliance report then request the rebate.
The FAA is not accepting reservation yet. It appears they won't do so until September 2016. All that's available now is notification of their intent to rebate $500 for ADS-B installation.
The hoops to jump through (requirements) to get the $500 are considerable starting with installation within 90 days of reservation. The reservation web site will not be up and running until September and will accept approximately 20,000 reservations. After that there will be no more.
The equipment must be certified. Probably the best way to start is to get equipment ordered so it will be on hand for install during the 90 day window. And if there is a delay, do not register until equipment can be installed within the 90 day window. Of course in the mean time, thousands of other purchasers will registering so in the end, the program will help only 20,000 of the hundreds of thousands of aircraft owners out there.
I am not impressed.
