Old 01-01-2007, 09:20 AM
aadamson's Avatar
aadamson aadamson is offline
Default Composite guys can do metal - well, sorta
Happy New Year all.
I just figured all you "metal heads" would like to see a picture of as much metal as hopefully I'll have to do.... And even this was cheating.
The baffling kit for my Lancair was all prepunched, pre-bent, sorta pre-drilled. But I've had to fit quite a bunch of it. In fact, even in this picture I found something that I need to go back and fix...
Ah, well, I'm not sure which I despise most - body work or metal work ...
Here's hoping all your resolutions come true. I only have one - to finish my Legacy!
Oh, and if you're curious, here's the business end of the "fire breathing dragon" thats going in my Legacy (a 370HP, IO-550)
Alan Adamson
Atlanta, GA
Lancair Legacy FG-6 - N60AL (fixed gear, carbon fiber, IO-550)
Lancair Legacy Builders Forum
Beta Test Blog of Vertical Power install
Old 01-01-2007, 09:23 AM
TSwezey TSwezey is offline
Just trying to get my Vertical, rudder, aileron and HS tips to look good has been a nightmare. If you can do composite you probably can do metal!
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 01-01-2007, 09:32 AM
pierre smith's Avatar
Default Sweet
Really nice......! You know, with that pretty blue case, have you considered having the baffles anodized a light blue?
Very nice,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-01-2007, 09:38 AM
aadamson's Avatar
I'm not sure what I'm gonna do with the Baffling. I'm working on paint designs now as well. Airplane will be mostly white with probably a blue and silver stripe. At the moment, leaning towards white powder coating on the baffling, the rubber seal strip is also blue....
Alan Adamson
Atlanta, GA
Old 01-01-2007, 10:49 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Nice engine
With an engine that nice looking, they should have crated it in teak!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-01-2007, 11:40 AM
cjensen's Avatar
cjensen cjensen is offline
That is just beautiful Alan!! Very nice, and I wish you all the best with your, uh, metal work ahead of you...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 01-01-2007, 01:47 PM
N395V's Avatar
N395V N395V is offline
Gosh Alan you are gonna have to make your cowl out of plexiglas to show that engine off./
Milt Concannon
Old 01-01-2007, 11:55 PM
osxuser's Avatar
osxuser osxuser is offline
Where is the engine from? Looks like one I saw doing breakin on a Legacy RG at POC the other day. A performance Engines build perhaps? (Just guessing here)
RV4 wing in Jig @ KPOC
RV7 emp built
