Old 06-07-2016, 12:23 PM
dwilson dwilson is offline
Default Metal tape on cylinders?
I have read of people using metal tape on the front cylinders instead of the air dams provided by the factory.
Can anyone recommend a brand name and source for this tape?
Duane Wilson
RV9A. Built, flew 1000 hours, Sold
RV10 Built, flying 330 hours so far.
Central Oregon
Old 06-07-2016, 12:27 PM
Jasonm Jasonm is offline
I think it's the HVAC foil tape you'd find at Lowes or HD.
Jason McKay
RV-10
Old 06-07-2016, 12:40 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
3M brand foil tape, readily available at either Lowes or Home Home Depot. Check both the tape section and the HVAC section. I think I found it in the latter.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 06-07-2016, 01:51 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
HVAC section around the ducting.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 06-07-2016, 02:48 PM
Default Thanks for the advice
I wasn't sure if the tape glue would hold to hot cylinder heads. I will give it a try.
Duane Wilson
Central Oregon
Old 06-07-2016, 05:48 PM
Yes, it will stick just fine. It has never come off or loosened until I've tried pulling it off.
Steve M.
Ellensburg WA
Old 06-07-2016, 06:48 PM
I would love to see a picture or two of what you are talking about. I am struggling with my plenum and baffles. Im ready to try anything!!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
