06-07-2016, 12:19 PM
Stafford, VA -- Twin RV down
Yes a twin RV. Bobbi did a couple of tech counselor visits on my RV-10 build. She might need surgery but it looks like she's going to be OK based upon a post on the DC pilots Facebook page.
http://www.fox5dc.com/news/local-news/154637177-story
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
06-07-2016, 12:30 PM
Well crud. I was watching that build process, I guess she was doing taxi testing prior to first flight?
Glad she's going to be OK.
06-07-2016, 12:34 PM
Apparently she had an inadvertent liftoff during a high-speed taxi test.
PP ASEL-IA
WAR EAGLE!
06-08-2016, 08:24 AM
I've lost track of the number of times i've heard of a high-speed taxi test going badly and writing off an airplane. I don't understand why some people insist on doing them.
Rob Prior
06-08-2016, 09:37 AM
Yup! It happens....
Read this:
It is a famous accident that happened in a Bombardier Challenger on a high speed maintenance check.
http://www.37000feet.com/report/4364...hooting-at-lgb
Wishing Bobbi a speedy recovery! Sorry to hear this happened.
John Mastro
RV-8
06-08-2016, 12:10 PM
Different aircraft require different kinds of testing. In National Test Pilot School, we discussed hi-speed taxi testing at length. The general opinion of our class was that this is not a necessary test for our type of aircraft.
The consensus was to begin one high speed taxi test with the intent of flying. If a problem is detected, shut it down and address the problem. If no problem is detected, continue with the first take-off.
Of course, people are different. That decision belongs entirely to the test PIC.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
06-08-2016, 01:31 PM
The first flight of the F-16 was on a high speed taxi test when the pilot PIOed in roll.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
06-08-2016, 01:47 PM
So many things look sketchy here..
- The most obvious... Unless you train/fly every other day two engines will just kill you twice as easy.
- With the RV stubby wings and stock tail - vertical stab - rudder. It's not far enough aft or large enough for comfortable single engine control. Not that it got that far... When I built twin RVs in X-Plane, they had to be bigger than stock.
- high speed taxi... please builder/pilots, do normal taxi until your comfortable. If you're not, then get someone else to test fly it.
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
06-08-2016, 02:03 PM
Ten years ago with my SuperCub ready for flight I ran into a problem that I'm glad I was still on the ground when I discovered it. With all that is taking place on the first flight I mismanaged the fuel system. I have four position on my fuel selector. Both and OFF are opposite each other (top and bottom) with left and right on each side. The big handle moves with your hand and pointer indicates the position selected. I selected left for start up and taxied out to the run up area there I selected the right tank for run up. Before take off I turned the selector to Both. Once I was ready to go I indicated on the radio that I was ready for flight and that I would make a high speed run and that if I became airborne I would continue with the flight. The taxi went great until I started to make the turn to back taxi for take off. The engine just quit. Long story short, in the busy preparation of first flight my mind must have been loaded and I used the long handle as the indicator rather than the point and had turned off the fuel. With power lines directly ahead the out come would not have been good.
Now one can say I messed up and I sure did. If you think it cannot happen to you, I do not want to fly with you. Just saying this high speed taxi saved my bacon. Any taxi would have done the same thing as long as the duration would have used the fuel in the line. In my RV-14A , I'm glad to have an Andair fuel selector that requires lifting the knob to turn it off. Obviously my situation must have happened to others for this to be developed.
Hopping for Bobbi to have a speedy recovery.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
06-08-2016, 03:00 PM
14 CFR 23.995 (g) Fuel tank selector valves must?
(1) Require a separate and distinct action to place the selector in the ?OFF? position; and
(2) Have the tank selector positions located in such a manner that it is impossible for the selector to pass through the ?OFF? position when changing from one tank to another.
Willing to bet that's been in there for many decades...and yes, I *know* this isn't required for E-ABs, but still...
