I'm a bit biased, since I help Geoff with his web site.
I've had the rudder trim installed in my RV-10 since it's first flight almost three years ago. I second Bill's comments.
I can't imagine how it would impede any maneuver. The springs can easily be over powered by your feet on the rudder pedals.
Depending on where you mount it, you do need to ensure that there are no other objects that will interfere, but that's just common sense.
Mine is mounted at the bottom of the center stack.
