Old 06-05-2016, 09:35 AM
clutch22 clutch22 is offline
Default Cat whisker clearance
I'm trying to get my CI-157P nav antenna installed on top of my VS. I wasn't expecting it to interfere with the rudder, but it does.
I assume it's okay to open up the angle of the cat whiskers??
Andrew Austin
RV-10
-Flying!
Old 06-05-2016, 11:44 AM
noelf noelf is offline
Yes it is. The ideal dipole antenna is straight across. The cat whisker geometry is a compromise between ideal electromagnetic wave probigation, ethstetics, and aerodynamic form / function.
Noel
RV-6A N6NF
tip-up
flying
Old 06-05-2016, 07:10 PM
Well, a little bit is okay. If you go to a straight across dipole you'll get no reception at 3 and 9 o'clock.
How about just installing it 'backwards', e.g., pointy ends forward?
Old 06-05-2016, 07:25 PM
9GT's Avatar
9GT 9GT is offline
I installed mine so that the puck protruded about 1/2" forward of the leading edge of the V/S and faired it in with flox and micro. Looks very nice and I have about a minimum 1/4" clearance at the tightest point. I used a fiberglass Comant IIRC.
David C.
Howell, MI
Old 06-06-2016, 06:16 AM
rleffler's Avatar
rleffler rleffler is online now
Actually, I believe that is the way Cobham recommends installing them (pointy end forward). Most of us, including me, install them backwards.
Please refer to the installation guidelines in case my memory isn't accurate.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-06-2016, 06:32 AM
Thanks for the responses.
I guess I just like the way they look pointing aft better. I worked on it last night, and it looks like it's going to clear by opening them up about an inch wider at the tips. It didn't need a whole lot.
Andrew Austin
RV-10
-Flying!
Old 06-07-2016, 10:59 AM
Robert Anglin Robert Anglin is offline
Default Yep me too
We did the same as above. After seeing a lot of Moonys down through the years and then talking to "RAMI" about it. We found that the VOR type antenna "Cat mouth hair type thingy" did not care which way you pointed it. Looks cool on there with the "V" facing forward. Sorry I don't do pictures on this sight to well. Yours as always, R.E.A. III #80888
Old 06-08-2016, 07:40 AM
flion's Avatar
flion flion is offline
Following are a couple of pictures of my installation. Too late now for you but might be an alternative for those who haven't gotten to this stage. No clearance issues at all. The puck nestles perfectly in the top VS rib flange and I protected the holes for the antenna with rubber grommets, both to prevent chafing and to seal the exits.
EAA Technical Counselor #5357
Old 06-08-2016, 08:44 AM
Yeah, I like this method. If I ever build another, I'd plan for this type of install. I'm about finished with my setup. Just need to rivet everything together. I may post some pictures.
Andrew Austin
RV-10
-Flying!
Old 06-15-2016, 10:13 AM
Here are some pictures of how I made my mount. Maybe someone will find it helpful someday...
Andrew Austin
RV-10
-Flying!
