Be careful..
..about working on the spars while they are sitting across a wing cradle. You don't want to have any "sag" or "twist" in the spar while you're working on it. That's why I found it was best to work on the benches. That way you can level it out along its length and keep everything where it's supposed to be. For the RV-10, Vans doesn't require the use of a wing jig, but they do still want you to work on a flat surface. IMHO, setting up the spars across such a long span might not provide this.
As a hint, I found, when shimming up my spars on top of my tables (they vary in thickness along their lengths) using old magazines was a great way to do this and get it just right, so everything was spot on flat, with no twist or sag, plus supported. Once I got it all right, I tapped the magazines to my tables, to keep everything in place.
