Old 05-31-2016, 05:04 PM
sahrens's Avatar
sahrens sahrens is offline
Default Ignition wire harness seal
Does anyone have a source for the ignition wire harness seal? I am working on my baffling and do not have the seals for the bendix magneto wires. I have checked Aircraft Spruce, Chief Aircraft and Wicks, although AircraftSpruce has a baffle seal for Slick wiring.
Thanks for your help.
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
Old 05-31-2016, 05:52 PM
dtw_rv6 dtw_rv6 is offline
Default An alternative to purchasing
You could wet out some fiberglass with some high temp silicone and use it to seal the wire into your through hole. Rivet some large aluminum "washers" over it when dry to keep it from peeling loose from the baffles.
I just used some large grommets that I bought from AS.
Don
Old 05-31-2016, 06:59 PM
jrs14855 jrs14855 is offline
Default Harness Seal
slick M2375 is a generic seal that works fine with Bendix mags with any of the common plug wires.
Old 05-31-2016, 07:35 PM
Fhuber's Avatar
Fhuber Fhuber is offline
I made some with 1/8 inch phenolic sheet from Aircraft Spruce.
Frank Huber
building RV-7A
dues paid for 2016
Old 05-31-2016, 08:36 PM
sahrens's Avatar
Default Thanks for the information
For $24.00 a piece I think I will try fabricating two before buying.
Scott
Old 06-01-2016, 10:09 AM
lr172 lr172 is offline
Frank Huber
building RV-7A
dues paid for 2016
I also made my own. I used 1/4" plastic from a $1.50 cutting board at Walmart.
Larry
