06-03-2016, 10:45 AM
Originally Posted by tturner
Saville
I did not need to use proseal. I just tightened up the loose one. The other side which I said was missing the ferrule also did not have a flare on the line. That was fun flaring a line inside of the tank. I did remove both of the tanks.
Ok thanks.
I'm hoping for just some loose connections. But whatever the problem is, it'll be fixed and done correctly.
Thanks!
Flying RV-8 N880BC
2019 Dues - happily paid.
06-04-2016, 01:29 PM
Originally Posted by Saville
Before it was fixed, did you notice anything odd about the fuel pressure reading?
nope. But that could be a shortfall in my observational skill...
Ed Neffinger
KCCR
RV7a
RV7
RV8
ATP, CFIA, II, ME, G
06-04-2016, 01:32 PM
Saville
I considered doing this to my vent line, re-flaring it... but my mechanic said replace the line, which was probably just as difficult. But he was the one doing the condition inspection.
Ed Neffinger
KCCR
RV7a
RV7
RV8
06-04-2016, 02:43 PM
Originally Posted by Russ McCutcheon
Thanks for the URL's.
I got the Mr. Funnel and used that to drain the tank. I'll use it to fill the tank as you suggest.
I got the access plate screws out and half the ProSeal cut under the access plate before I quit.
It's tight but I'm getting it done.
And yeah fingers crossed that:
a) All it needs is tightening and
B) I can do it without removing the tank.
But if it turns out that I have to remove the tank, I will.
Thanks!
Flying RV-8 N880BC
06-14-2016, 07:13 AM
The B-nut was loose
Well I got the access plate off. The builder used the cork ring.
I reached in and........
...I could tighten the nut with my fingers. So that's why I heard bubbles in the tank, at that position, when I blew air in the air vent intake.
So now I have to figure out how many turns past finger tight to go...or nut facets.
Then, more problematical, I need to figure out how to install the 2 1/2" fuel line that goes between the fuselage and the access plate....WITHOUT messing up the flares. I have to make a new one as I messed up the flare at one end.
That one is a real head scratcher but there must be a way to work it in as I re-install the access plate/sender assembly.
Flying RV-8 N880BC
06-14-2016, 09:08 AM
First check that the fitting is made up right, good flare and a ferrule
Second, torque it up to the spec in Van's manual. I doubt if you could over torque it considering its location. Hold the fitting that is in the rib so it does not turn and cause a new leak.
Third, put the cover plate on with Proseal, cork will most likely leak.
Lastly, get some Allen head screws with washers to replace the Phillips head screws that are a major pain to remove or install in that tight place.
If you use the soft tubing Vans supplies, it can be bent by hand enough (after forming) to get it in place without damaging the flare. Put one end on and tighten by hand, bend slightly to give clearance to the other end, loosen the first end slightly and get the nut started on the second and then tighten.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
06-19-2016, 08:44 AM
Ok so Major progress on the repair:
The B-nut on the inside of the tank is tight
The new fuel line was made - two actually because the first was a little bit too long.
Access plate installed with ProSeal only (no cork gasket)
fuel line installed but the nuts are just lightly snugged up - letting the ProSeal cure first before I put the final snug on those.
Fuel sender installed and wired. Line from the fuel pump to the sender cleared with air prior to installing the sender - just in case my cleaning of the threads wasn't careful enough and some material got into the hose.
Ok so after the ProSeal cures and the fuel line buts are snugged up, the testing can begin.
At the point of the testing where I fuel up the tank, I'm going to do it in 1 gallon increments and make a measured dipstick since I don't have one. Also going to check the amount in the tank vs what the EFIS displays to see if I need to do a re-cal.
I recall someone in the forum saying they made their dipstick out of a paint stirring stick. Not a bad idea - I'll search the forum for ideas there.
Flying RV-8 N880BC
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
