Old 12-30-2006, 01:30 PM
boom3's Avatar
boom3 boom3 is offline
Default Bad Pneumatic Squeezer???
I just bought a new Pneumatic Squeezer with the adjustable set from Brown a couple weeks ago. I've dimpled a lot with it but today I got to actually start riveting. I just about got all the rivets in the rear Horizontal Spar and all of the sudden it just stopped. It sounds like normal and everything, it just won't squeeze a rivet at all. I've checked my air is at 90psi and even tried another hose. I plan on calling Brown on Monday, but does anyone have any suggestions? I'm really having fun riveting!
Thanks!
Old 12-30-2006, 01:36 PM
fehdxl fehdxl is offline
Maximum sqeezing pressure is only obtained at the end of the piston's travel.
Is it adjusted so when sqeezing air (that is in the open without sqeezing a rivet) the gap is equal to the desired post-squeezing thickness of the rivet?
I hope this makes sense.
-Jim
Ron Ron is offline
Be sure you don't have the set adjusted to close, It will not squeeze if it hits the rivet before it has reached the end of the stroke.. If the set is coming up at all, I'm sure the tool is working...
Good Luck
Ron
FWF..9A
Old 12-30-2006, 01:37 PM
rvbuilder2002's Avatar
Did you maybe change to settign a longer rivet?
You need to readjust the plunger for different length rivets.
Sometimes if it is mis adjusted it wont squeeze the rivet hardly at all.
A squeezers mech. works in such a way that it gets the most power at the end of its stroke, not the beginning.
Scott McDaniels
Hubbard, Oregon
Old 12-30-2006, 01:39 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
You may have the adjustable set out too far. The squeezer should be set so the finished rivet is set to it's proper height at the end of the stroke. Also, when dimpling, run the squeezer out to full stroke and adjust the set so the dies just touch. I, and most likely others, have experienced the seemingly weak squeezer. You never want the squeezer set so it can't reach the end of the stroke. That is where it is most powerful.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 12-30-2006, 03:36 PM
BrownTool BrownTool is offline
Jeff,
I happened to read this post while in the office Saturday afternoon...I tried to call you, but the only phone number we have is your office number.
The issue you are experiencing is most likely not a problem with the rivet squeezer at all, but like most of the other posters have suggested, is caused by using squeeze sets that are too long or having the adjustable set holder out too far. In order for the rivet squeezer to reach its full power and properly squeeze a rivet, it must be able to "get over the hump" and cycle through its full stroke. When the travel of the squeezer is limited by either the use of too long of a squeeze set or an adjustable set holder being extended out too far, the unit will run into a "brick wall" and not reach its full compressive force. As the others have suggested, try backing the set holder off some or using thinner squeeze sets or a combination of both - this should alleviate the problem you are having and get you back to riveting.
If this does not solve your problem, please call me Monday morning and we will get you fixed up.
Thanks!
Michael Brown
Brown Aviation Tool Supply Co.
In beautiful Oklahoma City!
www.browntool.com
800-587-3883
Old 12-30-2006, 04:02 PM
boom3's Avatar
It works, I'm dumb. I had been adusting it all morning for the different sizes and I guess on this one I started going the wrong way, and when it didn't work, I closed the gap even more which just made it worse. I just went out and opened the gap all the way, then started working back down until it was perfect.
Thanks all.
Oh yeah, how often should you oil one of these?
Old 12-30-2006, 04:11 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default No oil
Not sure about the brown model, but the Avery doesn't get oiled. Something to do with possibly damaging a leather seal inside, or something...
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 12-30-2006, 04:16 PM
mlw450802's Avatar
mlw450802 mlw450802 is offline
Default another "no oil"
I have an Atlantic Air Tools squeezer and it specifically states no oil as well.
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 12-30-2006, 05:08 PM
cytoxin's Avatar
cytoxin cytoxin is offline
Default careful dimpling with it
careful dimpling with it, esp on soft stuff like hinge stock. it will warp stuff like elev spars among other things. start with a smalll amount of dimple and work into it untill you just feel the bump.i index my adjustable set holder to the yoke. it turns as i use it.
good luck
William Weesner/ still kicking.
