I took a few pieces of scrap chicken wire, some scrap trim lumber and built a collapsible priming table for my garage. The back has hinges and the front legs have bolts with wing nuts on the outside for easy setup. Not bad for a first effort. Will tape some plastic on the wall and lay down on the floor when I'm priming. Not sure if it will work ok, but I didn't want to take up a lot of space. The main flaw that I see so far is that it's a little too wide and thus sits a little too high. I should probably take 6 inches off the width and drop it down the wall so that it sits a little lower, but I'm kind of tired of working on it and will see how it goes. I'm using water based paint so I'm going to forgo the venting and see how it goes.
The next phase of the plan has side walls that swing away and would be covered in plastic to keep overspray contained a little better. I added velcro wraps to keep the legs up so they won't fall into my wife's car.
