Old 02-14-2018, 02:55 PM
RV7A Flyer's Avatar
Originally Posted by Bluelabel View Post
I used the Safe Air kit and the ports as provided.. I believe that mine would be considered flush. Is that right? Jesse, I just started flying, so how do you know if you are getting airspeed errors? I'm seeing IAS and TAS in the range I would expect for the plane in the current configuration I'm flying.
If you used these
http://www.cleavelandtool.com/Push-O.../#.WoSvpaJu6kI
then I believe they are *not* considered "flush". They do protrude above the skin, as noted in the description.
That's what I have, and airspeed seems to be right on the money.
(Note that I don't know for sure, but perhaps an earlier version of these *was* actually flush with the skin when installed?)
2019 Dues paid!
Old 02-14-2018, 03:16 PM
rvbuilder2002's Avatar
Originally Posted by Mudfly View Post
Must be.
I hadn't heard anything about it.
I imagine it is a vendor produced part being offered as an (additional) $30 option for those that don't want to use the blind rivet supplied in the $19 static system kit.
Scott McDaniels
Hubbard, Oregon
Old 02-14-2018, 03:21 PM
Originally Posted by RV7A Flyer View Post
If you used these
It all depends on the vintage of the parts that someone has....
I think Cleveland, Safeair, and perhaps others originally offered a rivet on static port that had a flush profile. After enough users had errors because of incorrect static pressure, they redesigned the part.
If someone has ports that look flat/flush to the outer skin, and do not protrude to mimic the recommended blind rivet, the should count on there being some error in their ASI and altimeter.
Scott McDaniels
Hubbard, Oregon
Old 02-14-2018, 03:26 PM
Richard Connell Richard Connell is offline
The original Safe-Air “flush” ports were most definitely wildly inaccurate. I saw cruise TAS errors nearing 10KTAS and commensurately large altitude errors.
The Cleveland ones that mimic the vans rivet I can report are super accurate.
This has been extensively covered before so worth a search.
The new vans screw version looks like a good compromise between the convenient but probably overkill push fitting Cleveland one and the rivet method which some people struggle with for various reasons.
Cheers
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 02-14-2018, 03:35 PM
pauldan181 pauldan181 is offline
I bought the static ports from Cleaveland probably around 2002 and they were absolutely flush. I had errors (low and slow) that got worse with increasing airspeed.
Paul Danclovic
Jamestown NC
RV-8A N181SB
Old 02-14-2018, 05:26 PM
Champ's Avatar
Champ Champ is offline
Checked a lot of posts and it seemed that the Vans rivet static port worked well and people had a lot of trouble with other systems so I decided to stay with it and just change the internal tube connection. So - son machined a couple flanges with threads for Parker fittings, scuffed mating surfaces and applied a little proseal (just because) and pulled the flanges tight to the fuselage with the Vans rivets.
Picture during construction:
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2020 Donation In
