Go Back   VAF Forums > Main > Safety
  #21
Old 05-27-2016, 03:12 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
My example was talking about a typical small GA airport whose runway is usually at least 3000-3500' long. In that case, there is no reason that heavy braking should be required to stop in only half the runway length or less.
Absolutely. I rarely touch the brakes until I need to turn off at the end of the rollout. Captain McBrakes might like to do a Valdez STOL-like arrival every time, but approaching at Vref with a near-stall touchdown lets you slow to taxi speed on most runways without needing the brakes.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 05-27-2016, 03:14 PM
ChiefPilot's Avatar
Originally Posted by RV7Guy View Post
I think what happens many time is that we fly around on our planes at 170kts for a while then have to slow down to 65kts for final. It doesn't feel right So we keep it a little faster. Becomes even more critical when landing on a short field.
I'd argue that 65kts is sometimes too high. Computed Vref for me, bags, and gas in my -6A is 59kts.
Old 05-27-2016, 05:24 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Lightbulb 65 kts?
As has been mentioned, the air speed is the key. Most, self included, approach too fast. The landing on a long runway is excellent advice.
You should have no problem with transition training and practice. The main goal, "Landings equal Take offs."
If I am on final (RV7A IO360 CS) with power off at 65 kts my sink rate picks up rather fast. I am typically over the numbers when below 65 kts. My touch down speed according to my Dynon data is about 52 kts IAS. Typically I have an 8 kt crosswind when landing and touchdown within 500 ft of the numbers and turn off using about 2K ft of paved runway. My DA is typically 4k+. I want to shorten my landing distance without heavy braking. Each flight I challenge myself to improve my landings even though by most standards they are very safe and smooth. I am not allowed to harm my RV!!
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
