Old 12-29-2006, 10:52 PM
conlimon conlimon is offline
Default Assembling Matco master cylinders
hey all -
i've disassembled my master cylinders for powdercoat, and now i'm putting them back together. My question is - I don't have any aviation brake fluid handy just yet, and I need a bit of lube to re-assemble. Can I use automotive ATF just to assemble? I'm not going to use it as brake fluid as some do - just need something so the seals slide in easy, that's compatible with aviation brake fluid.
thanks -
cj
Old 12-30-2006, 07:35 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Buy what ever you are going to use anyway. That way you can be sure of compatability. A qt. can of Mil Spec brake fluid is way more than you will need.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
