There are only three wires that need to go from panel to P-MAG, power, P-Lead and TAC signal. My power and TAC are unshielded wire and the only reason I have a shielded wire for the p-lead is that I had used that for my SLICK which required a shielded wire. With this setup, I do not have any noise from the ignition.
If you are going to be pro-active, you might want to run two more strand of wire for Rx and Tx if you ever decide to install a EIC which also does not need to be shielded.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
