05-23-2016, 04:47 PM
Is 14.5 volts to high?
My EIS is reporting 14.5 volts put out by the alternator.
Is this to high?
Al Girard, Newport, RI
N339AG
RV-9
05-23-2016, 04:54 PM
Perfect for the PC680.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
05-23-2016, 06:40 PM
if its the same as a 12V automotive charging system that is perfect! id be worried after 14.9 and up. 15.0v can start to boil batteries.
Andrew Atalla
Red Seal Automotive Service Technician
Red Seal Heavy Duty Equipment Service Technician
Welder/Fabricator
Squamish BC CYSE
RV-7 Left Elevator in progress
Dues paid
05-23-2016, 06:51 PM
I don't know what the AGM batteries will accommodate, but that is high for an alternator. I thought most auto alternators run 14.0-14.2 range. In a flooded battery, in the upper 14's you are in the equalize stage and your losing electrolyte. Put a meter on your battery and test. The only thing that matters to the battery is the voltage on it's terminals
05-23-2016, 07:38 PM
Just a data point - I thought 14.5 would be high too, but I took an alternator off a late model Tahoe and it tested at AZone at 14.5, just like on the vehicle. Their chart said 14.5 was the spec, and the new one from the box tested exactly the same. I reinstalled the old one.
Bill
RV-7
Lord Kelvin:
05-23-2016, 09:07 PM
I believe you, but I have to wonder if that doesn't take it's toll on the batteries longevity. I know that the max float voltage for lead acid batteries is about 13.8. Charging is acceptable up to around 14.75, but not floating. It's all about compromise, I suppose. By uping the charge voltage to 14.5, the OEM drives a much better and faster charge rate at the expense of battery life.
I had a 2000 BMW and I think it's alternator voltage rate was 14 volts. I got over 7 years and 75,000 miles out of the original battiery. I don't believe you could do that with a 14.5 volt float level.
I used to design and sell large UPS systems as part of large telecommunication systems. The units had a float setting (13.75 volts) and an equalize setting for charging and de-sulfication (can't remember the figures we used, but upper 14"s). Customers would equalize every 3 months (to de-sulfate the plates) and one customer forgot to switch it back to float. They had an outage and only got about 20% of the designed reserve capacity of battery group.
Larry
05-23-2016, 09:44 PM
Do you fly short local flights? 14.5V is no problem.
If you fly very long cross country legs all the time, You might like a slightly lower voltage on a flooded cell Lead Acid battery.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
05-24-2016, 05:37 AM
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
05-24-2016, 05:53 AM
If you have a 12v aux power plug, you can purchase a plug in voltmeter on Ebay or Amazon to check the voltage at that point. About $4-5 and useful to cross-check your built-in voltmeter.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
