Old 05-23-2016, 05:58 AM
rleffler's Avatar
rleffler rleffler is offline
Default 91.413 and 91.411 Questions
To all the IAs, APs, DARs, etc,
In both 91.413 and 91.411 (pitot/static and transponder testing) it states that the manufacturer of the aircraft may make these tests if the appropriate calibrated test equipment is used.
I've not heard of anyone with a Repairman's Certificate performing these tests. It appears that we are authorized by the FAR as manufacturer of the aircraft.
So other than the cost of the appropriate hardware, why aren't folks performing these tests? Am I missing something in the FARs?
thanks,
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-23-2016, 06:04 AM
Mel's Avatar
Mel Mel is offline
Default This has been discussed before.
thanks,
bob
Because in the context of 91.413 and 91.411 we are NOT considered to be the aircraft manufacturer.
Walt will be along soon to explain further.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-23-2016, 06:18 AM
Walt's Avatar
Walt Walt is online now
This question comes up at least once a year, below is the answer which I copied from the FAQ section of my website (which also has other common questions/misconceptions):
"The FAR?s authorize the "manufacturer" of the aircraft to conduct the tests However, the builder of an amateur-built aircraft does not meet the FAA?s definition of a manufacturer. The FAA, in Order 8130.2, defines a manufacturer as a Production Approval Holder (PAH). Some examples of a PAH would be the holder of a Production Certificate (PC), a Parts Manufacturing Authority (PMA), and Technical Standards Order Authorization (TSOA). An amateur builder does not fit this definition. Thus, the amateur-builder cannot perform the transponder and pitot/static tests on his/her homebuilt."
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-23-2016, 06:25 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Slightly different question... Does the transponder certification for VFR (91.413) require static system test or is it only transponder / encoder that gets certified?
In other words, if static system has small leak does that impair the VFR certification process?
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 05-23-2016, 06:40 AM
Walt's Avatar
No static system tests are required for the 'VFR' transponder check:
What inspections are required for VFR operations?
"The aircraft transponder must be certified every 24 months in accordance with the requirements of CFR. 91.413. Transponder testing is accomplished in accordance with Part 43 Appendix F.
Note: For new certifications or if the encoder or altimeter has been replaced, a Data Correspondence Check must be accomplished to ensure the altitude data transmitted to ATC corresponds to within 125 feet of the altimeter normally used to maintain flight altitude per CFR 91.217. "
Old 05-23-2016, 10:36 AM
rleffler's Avatar
Thanks Walt!
bob
Bob Leffler
Old 05-23-2016, 01:05 PM
I think if one were so inclined, you could argue with the FAA. FAA orders are their interpretation of the law, not the law itself. However, it's academic. The cost of required, frequent re-certifications of the equipment makes this a non-starter for the typical owner.
Old 05-23-2016, 01:43 PM
Mel's Avatar
Mel Mel is offline
You could certainly argue, but you would not win. It's not a law, it's a rule.
It's their rule and they get to interpret it. And they have.
