Old 05-22-2016, 02:08 PM
judoka5051 judoka5051 is offline
Default RV-8 Fastback weight savings = 9 lbs
Hey All,
When I started researching the fastback option I noted a poster that asked about the weight differential. As far as I can tell no one has ever done a weight comparison until now. I'm converting a partially built 8 from a slider to a fastback. It had all the slider hardware installed, so it was easy to do a before and after weight since all the removed parts ended up in a pile. The fastback mod I'm doing is a "Showplanes" kit,,, mostly. I raised the turtledeck 2.5 inches to get rid of the 'bubble' effect. Anyway, I weighed all the pieces that came off and compared that to pieces being added and found that I'll save a smidgen over 9 lbs.
BTW, I had to use 2 pieces to form the new turtledeck, There's no way to get it done with a 4ft wide sheet. Bummer!
Lance Logan
McAlpin, FL
Plane at FL10
Scratchbuilt Biplane
Preceptor N3 - Sold
Zenith Zodiac 601HD - Sold (good riddance)
Kitfox IV - Sold my share, but loved that plane
RV8A Sold! Loved the plane, but not the nosewheel!
RVX (RV6/4) Sold
Cherokee 180 pickup truck
RV8 Fastback
Old 05-22-2016, 07:11 PM
rv7charlie rv7charlie is offline
Have you built & weighed the canopy itself yet?
Charlie
Old 05-23-2016, 04:51 AM
Hey Charlie,
In individual pieces and cleco'ed together for the dry fit. Actually, it will still lose some more weight when I trim off the excess, but not more than 1/2 pound or so.
Lance Logan
McAlpin, FL
Plane at FL10
Preceptor N3 - Sold
RVX (RV6/4) Sold
RV8 Fastback
