Old 05-22-2016, 10:38 AM
flightlogic's Avatar
Default Moving my RV backwards
In the last few months I have left my towbar to gather cobwebs.
I have been gently pushing the tail down at the junction of the vertical and horizontal. It doesn't take much force on my 9A. I then simply sit on the horizontal and the plane feels like it is just about at the balance point... like a nice nose up landing. Walking backwards is then simple and turns are easy.
Is there a reason I should not use this method? I do have the antisplat reinforcement in the tail... but from the forces applied, I don't think I am applying any more than in-flight maneuvers would push on those surfaces.
If I am mistaken.... feel free to correct me with replies here. Have a great Sunday as well.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 05-22-2016, 12:49 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I disagree. You are applying unbalanced and concentrated force on a structure designed to have load applied evenly over the entire surface.
Practice pushing the plane back without a tow bar. You will soon get the hang of doing this without the nose wheel cocking over.
Carl
Old 05-22-2016, 04:02 PM
lr172 lr172 is offline
Carl
I have to push back after every flight and you will get good at it pretty quick. I made a towbar, but is easy enough that I don't bother getting it out of my trunk.
Larry
