Quick question before I cut the wrong thing...
Search didn't get me anywhere, so forgive the newbie question.
Working on RV-8 wings, the manual says, "Make the wing walk doubler (DWG 17A) from AS3-025x9 3/8x26."
I have two sheets of AS3-025, both measuring 10x48. Am I correct in assuming I should use these sheets and cut pieces 9 3/8x26, and that the rest of each sheet (which will be 22" long minus kerf) is used for something else? Or do I need to keep looking for a 9 3/8x26?
Even as I ask, it sounds stupid, but the manual says what it says......
Thanks in advance.
Stu F.
RV8
