This is how I wired mine, bus A fuse block, one ecu, pump, ign coils, the other set on bus fuse block B, and bus C for all avionics and what have ya, I have two batteries one on the master relay, and through a different firewall pass through, back up battery going through a 30A switch that feeds bus A and B, a heavy switch controls bus C a schotsky heat sink diode feeds the backup battery. I have 7 switches for the EFII system.
