Old 05-19-2016, 10:27 AM
jdmunzell jdmunzell is offline
Default Priming the inside of steel aileron balance tubes..
Howdy all... I know there's lots of info out here on priming, but I have a question about the aileron balance tubes. I think they're made out of steel, but not really sure. These also are not closed up during aileron construction. My question is about priming the inside of these things, and what type of primer would work best on this material..
Jeff
-8 wings, finishing up
-8 QB Fuse just arrived!!!
Old 05-19-2016, 12:48 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Priming them is probably more effort than is necessary, but you certainly can swish some primer around in there.
YMMV!
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 05-19-2016, 12:52 PM
rmartingt's Avatar
I believe these tubes are galvanized, so they're pretty protected as it is. I primed the outside of mine because they'd be in contact with the skin, and I sprayed some primer inside as well.
RV-7ER - finishing kit and systems installation
Old 05-19-2016, 12:54 PM
I primed the inside of the aileron skin so that there wouldn't be any dissimilar metal to metal contact, and sprayed the ungalvanized inside of the pipe with primer, too.
Dave
RV-3B
Old 05-19-2016, 04:38 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tip
I have a neat tip.
Cut the fingers off a nitrile flove and slip over one end. Pour in the primer and slip one on the other end. Slodlsh and remove one to pour it out.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
