Old 05-17-2016, 07:24 AM
StuBob StuBob is offline
Default Help Me Plan Wiring in the Wings
Pardon the curiosity dump here, but I have a lot of questions.
As I see it, here's what has to be wired or plumbed in the wings:
Pitot, AOA, Pitot heat
Nav lights
Strobes
Landing/taxi lights
Wingtip Nav antenna (possible, but assume it's there for planning)
Magnetometer
Is that about right?
Right now, I'm about to start the wing skeleton, which would be a better time to drill a bunch of rib holes than after it's together.
I'm planning wingtip landing and taxi lights, but I'm open to correction. Also planning heated pitot/AOA, likely Dynon.
The Pitot tube has its own dedicated holes. Where do you route the AOA line?
If I drill a 3/4" hole in each rib and run a conduit out to the tip, is that large enough for all of the wires?
Is there an advantage to running wire through grommets instead of conduit?
Thanks in advance. Great site, great people, etc.
Stu F.
RV8
Old 05-17-2016, 07:43 AM
paul330 paul330 is offline
VANS support site has a Service Letter detailing wing wiring routiyng.
As for conduit vs grommets, I prefer grommets. Simple reason is that I don't want wiring hidden for years in a tube where it can't be seen/inspected. But that's just me - most people around here seem to go with conduit.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 05-17-2016, 09:46 AM
Some of the RVs use a wing-mounted autopilot servo, if you're planning on that feature.
Dave
Old 05-17-2016, 09:54 AM
wirejock's Avatar
wirejock wirejock is offline
Default Routing
Whichever you decide, consider how the cable or tube will transverse the bellcrak and or AP servo.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-17-2016, 10:36 AM
Something I hadn't thought of.
Is it a particular brand of servo that goes in the wing instead of the fuse? And where does it go?
Stu F.
RV8
Old 05-17-2016, 10:49 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
The servo is often mounted in the same bay as the aileron bell crank.
One more item that some folks install is a camera-----infrared or other.
Also, APARS tracking unit.
Leading edge landing lights? or wing tip? Flash the landing lights or separate wigwag lights?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-17-2016, 10:57 AM
Auburntsts's Avatar
A couple things that could also be wing mounted: aileron trim servo and OAT sensor.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 05-17-2016, 01:42 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Better to run a few too many than one too few.
On my -9A, it was a real pain to run wires from the wing through the fuselage to the panel, so plan for that as well.
Consider if you want quick disconnects at the wing root.
Make your wires plenty long (service loops). The rule is that the wire should be long enough to allow you to put on a new connector three times.
Mark or use colored wires.
Got to rewire one wing of the -9A when we upgraded the avionics, and it the previous installer had done some of these things...
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 05-17-2016, 02:10 PM
Ideally, landing lights in the tips and separate LED strobes. But it seems it could get pretty crowded out there.
Stu F.
RV8
