Old 05-16-2016, 03:01 PM
LuisR LuisR is offline
Default Transport partially complete -10 tail
Any tips on transporting RV-10 tail parts:
Completed rudder
Completed Vertical Stab
Completed Horizontal Stab
Partially completed elevators.
I have a short bed Crew Cab Silverado and a single axle 8 or 10 foot trailer.
The biggist piece (H. Stab) is 134" or just over 11 feet. Any suggestions on best way to orientatie it, flat, on aft edge, etc...
For anyone who has done this before who did you do it. It's a 2 hour drive on the highway.
Thanks.
Regards
Luis
---------------------------RV-10---------------------------
Empennage. Complete Minus fiberglass and attach section. FOR SALE
Build Log N925LC (Reserved) YouTube
Old 05-17-2016, 05:31 AM
Jasonm Jasonm is offline
If it were me and with the drive being relatively short, I'd ride down with someone and rent a box truck one-way to bring it back. All those parts are very light and the thought of them bouncing around on a trailer for two hours makes me cringe. At least with a box truck you'll have more of a suspension and not to mention plenty of tie down points.
Just a thought.
Jason McKay
RV-10
Old 05-17-2016, 05:44 AM
KatanaPilot KatanaPilot is offline
Default Have you thought of this?
A year or so ago I moved RV-10 parts from Pompano to Atlanta (empennage, tailcone and wings) in a 16 foot trailer. You have much less to move and a much shorter distance.
My empennage and wings were in cradles, which helped, but if I were you - find a company that sells furniture pads in bulk. I'm not talking U-haul, but there should be someplace local that has them. Don't buy the cheap ones that U-Haul or Penske rents when you rent a truck - buy the heavy duty ones like the movers use.
Buy at least a dozen and use them to wrap up each of the parts and use bungee cords or even packing tape to secure the blankets to the parts. Strap them down if you can but the ride on the SSP should be OK from Orlando to South Florida. The ride in the truck bed is probably smoother than in a single axle trailer.
I bought 3 dozen furniture pads a few years ago when my mom passed away. Seemed a bit excessive at the time, but that has become one of my more useful purchases. I used every one of them when I bought the tail and wings in Pompano and had zero damage.
You probably got the deal of the century buying that tail kit. You should spend a few more $$$ to move it safely.
Krea Ellis
Old 05-17-2016, 06:02 AM
rleffler's Avatar
rleffler rleffler is offline
Do you have the stands that were used to build the horizontal? I moved mine in the stands vertically.
The other parts can be laid flat as long as they're padded and supported with tie downs to keep them in place.
How long is your bed with the gate down?
I've moved several sets of built RV-10 wings in the back of a pickup in their stands. Not a big deal if anchored properly.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-17-2016, 07:52 AM
Just a thought.
I agree 100%. After starting the thread, I decided a box truck would be best for reasons you mentioned.
Regards
Luis
Old 05-17-2016, 07:56 AM
Katanapilot,
Yup, all good points. Will look for some movers blankets.
Did you finish the pompano -10? Your building a second?
Regards
Luis
Old 05-17-2016, 08:03 AM
The seller will be building a -9. So not sure if he will part with cradles.
Bed with gate down is 8'. H.Stab would have an overhang of 3'.
If I can build the cradle for the H.Stab then I would put it in the bed. Hmm.
I'll have to dig up cradle plans. Have a link?
Regards
Luis
Old 05-17-2016, 08:04 AM
Default Yes and No
I'm keeping the wings and I just built a new tail out at Synergy. Needed to learn the skills and gain confidence in my abilities. Synergy provided me with a good start on both.
Waiting for tail to be shipped back to Georgia. In the meantime, I will finish the wings and get ready for a return to Synergy in September to build a fuselage shell. Already have a QB fuselage, but the sheet metal was damaged in transit from Van's - so the prudent thing for me is build a new shell rather than try to repair the one I have. Would be a good project with someone on a budget and with more experience in sheet metal.
Given the pace at which I learn and progress, you will probably be flying before me!
Good luck on the transportation and with your build. Go see Lenny!
Krea Ellis
Last edited by KatanaPilot : 05-17-2016 at 08:05 AM. Reason: edited grammatical and textual error
Old 05-18-2016, 07:22 AM
Built 4 cradles using the strap method last night after work. These will be used for the H Stab. Thinking of building more for the V stab and rudder. What do you all think?
Will be using a 14 ft box truck rental. Hopefully the weather cooperates.
Regards
Luis
Old 05-18-2016, 09:10 AM
Default Good plan
I had cradles for all the parts, except the tailcone - which I strapped to the floor on top of moving pads. Again, moved 700 miles and no issues. The cradles will be useful for storage at your build location, too.
It's South Florida - pick it up in the morning and unload it after 4 P.M. You'll miss the rain (Grew up in South Miami)
Krea Ellis
