Old 05-15-2016, 01:32 PM
Daida's Avatar
Daida Daida is offline
Default Ignition harness routing
Hi there!
Thinking about running the ignition harness from the lower cylinders. I want to put adel clamps on the lowest screw from the valve covers and run the ignition, CHT and EGT wires through. I know it has been done before, just want to confirm that i have to grind of a little bit off the edge of the valve cover to make the adel clamp fit flush.
Pictures will be appreciatet, big time!
Thanks in advance
Daida
RV-8 QB Germany
ECi XIO-360
Dynon SV
Flying since 11th July 2020
Old 05-15-2016, 01:47 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by Daida View Post
Hi there!
Thanks in advance
Daida
Don't grind the lip off the valve cover. Instead, place a washer between the clamp and the cover.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
