Old 12-29-2006, 07:52 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default riveting trailing edge
What are the tricks for riveting the skin to the rib near the trailing edge of the elevator. I can't get a bucking bar or a rivet squeezer in there. I used an axe blade as a bucking bar but I can't even get that into the last hole space.
Thanks, Andrew
Old 12-29-2006, 08:14 AM
mburch's Avatar
mburch mburch is offline
Assuming you are able to dimple the hole (pop rivet dimpler, vice grip dimpler, etc.) I'd just drill up to 7/64", throw a MK-319-BS blind rivet in there, and move on. Like one of my buddies always says, you won't be able to tell it's a pop rivet when I'm flying over your house anyways.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 12-29-2006, 08:17 AM
Caveman's Avatar
Caveman Caveman is offline
Default Special tool
IIRC... Dan Checkoway's site www.rvproject.com addresses the issue. I was able to spread mine enough and then rebend them. I used Avery's dimple vice grips. I later bought Cleveland's special tool in case similar situations come up again. I haven't used it yet though. Here is a link:
http://cleavelandtoolstore.com/prodi...mber=DIE4263DF
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 12-29-2006, 11:13 AM
craigvince's Avatar
craigvince craigvince is offline
I bought a no-hole C-yoke for my rivet squeezer. This allows me to get into places with as little as 1/4" clearance. Try to find someone nearby to borrow one from, though, as you won't need it very often.
Old 12-29-2006, 11:52 AM
N941WR's Avatar
N941WR N941WR is offline
Andrew,
Not to be rude, but please do a search on this subject. There are a lot of VERY good threads on this subject in the archives.
(You can also check out my site, as I have yet a different way to rivet these things up.)
Best of luck with your project!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-29-2006, 01:23 PM
TSwezey TSwezey is offline
I'm with Matt. The sheets of aluminum will fail way before the MK-319-BS fails. Take a look at the bird strike Thread on the RV-10. The skin tore and the rivets didn't fail.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 12-29-2006, 04:29 PM
Les Dial Les Dial is offline
Axe blade!! Wished I'd thought of that! Me and my buddy Dave actually used the flat end of a crow bar that we polished up to do the aft/lower most rivets of the rudder trailing edge. After that, I bought the 4" No Hole yoke. Good investment!
Les Dial -- Rv-7 Wings
