Old 05-14-2016, 07:34 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Default Canopy Crack
Probably the oldest story in the book. Cracked the canopy while riveting it to the frame this afternoon, but stop drilled it immediately. I will get some weld-on, but was wondering what to plug the hole with. I know RTV isn't a good choice, but wonder what everyone else has used, I was thinking about using a little DAP Alex caulk since it dries clear.
Pic below:
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 05-15-2016, 07:20 AM
cjhammes's Avatar
cjhammes cjhammes is offline
I've seen a lot of RVs with a bead of pro seal run around the skirt/canopy perimeter. Makes for a nice finish. In your case would also cover the hole.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 05-15-2016, 09:31 AM
Saville's Avatar
Saville Saville is offline
Is ProSeal also the recommended material for a bead on the windshield where the windshield meets the frame?
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 05-15-2016, 10:13 AM
gasman gasman is offline
Glue in a clear plastic toothpick type. Cut flush to surface and buff. Did this on a 150 with very good success.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 05-15-2016, 11:55 PM
vickruis vickruis is offline
We also had a little crack; stopdrilled and filled with this stuff, barely visible.
Victor Kruis
RV7A
PH-OBO (The Netherlands)
Flying!
http://www.hobopagina.nl/RV7a/Index.htm
Old 05-16-2016, 05:00 AM
Good point. I was already thinking about running a bead of proseal or sika, so this might be the answer
www.marksrv8.com
Old 05-16-2016, 05:23 AM
jump4way jump4way is offline
Default Fillet
I closed off the skirt to canopy with sika and it worked well and this would be easy to cover up in that manner.
