Progress Report:
This weekend I got the access panel off the left hand fuel tank.
It had the cork ring.
After removing the access plate/sender assembly I reached in and felt for the B-but on the air vent:
I could tighten it with my fingers. I went in with the bore scope to have a look at the flange and this is what I saw"
Flange looks ok from the outside.
I pushed the nut up the vent tube a ways and took this:
Doesn't tell me much but it looks ok. The lighting that comes with the borescope is a little weak - I need to enhance that somehow. I shoved a headlamp into the tank to get this lighting but it isn't great.
Anyhow, that was why I was hearing bubbles coming out of the inside of the tank at the air vent fixture: the B-nut was loose. I don't know if it was always like that, or if it got that way or how it got that way.
I have to figure out how many turns or facets past finger tight I need to make this connection stay put: I REALLY do not want to remove an access plate again if it can be avoided.
Learned a lot though, as always - easy for me to do as I don't know much
I'm also going to have to fashion a new one of these:
As I messed up one of the flange ends. It is the line connecting the tank fuel pickup to the fuselage fuel line plumbing.
Getting it back on without ruining the new one is a real head scratcher for me as well.
Onwards and upwards.
