Old 05-11-2016, 06:52 PM
Bugsy's Avatar
Bugsy Bugsy is offline
Default Zero G maneuver for AOA calibration
I am trying to calibrate my AFS AOA and looking for advise on the zero G maneuver.
Is the a best way to perform this maneuver? I tried slow flight and just shoving the nose over but the calibration didn't take.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 05-11-2016, 07:28 PM
DragonflyAero DragonflyAero is offline
I would think any ballistic push over would do. No need to be particularly slow. From cruise pull the nose up 30 degrees or so then push to zero g's and hold. You will get much more time at zero g's with more airspeed going in. Just start with the nose high so you don't have too much nose low when you finish.
Bill Vinson
RV-7 Standard Build
http://www.mykitlog.com/users/index....r&project=2226
Old 05-11-2016, 08:13 PM
I've found it handy to leave something loose in the cabin as a gauge. When it starts floating, there you are.
Don't let it get into the controls, though!
Dave
Old 05-11-2016, 08:30 PM
Michael Henning Michael Henning is offline
Unstrap the passenger, when she starts floating, you're there.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 05-11-2016, 08:37 PM
thinkn9a thinkn9a is offline
Default Suggest start at 120 or so
Already in calibrate zero g/lift mode,.... Pull throttle
Red button IN
then pull up and push over,...don't try to get on the edge of stall or slowed that much (say 70 or so)
As your pre-positioned piece of foam comes off the top of the panel,..hold it one second
RELEASE the red button,...
And then proceed to slow descending flight recording
Confirm all with slow flight and approach to stall,.... Try again if need be
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 05-11-2016, 09:43 PM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
What Wallace said, the key is to hold the red button and release it as your object (tennis ball, foam, loose passenger) starts floating.
Don't shove the nose over and go into negative Gs, just nice an easy to make it float.
Lenny
Old 05-11-2016, 10:46 PM
SMO's Avatar
SMO SMO is offline
If you know someone who will lend you a G Meter, swap out one of your other instruments for the flight(s). I found it much easier to nail this using the G Meter than with other methods.
The second best method was to take a passenger, have them hold a tennis ball and tell you when it starts to float. As others have said, that is when you release the red button.
Depending on where you mounted your buttons, it can be quite a trick to hold the button, push with just the right pressure on the stick, while simultaneously watching for something to float.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 05-11-2016, 11:52 PM
crabandy crabandy is offline
This training syllabus is extremely valuable, I can't think of a better way than using the "ballistic recovery" technique to master 0 G's and unusual attitudes.
http://www.vansairforce.com/communit...ad.php?t=93661
RV 7 400 hours and counting
19 donation done
Old 05-12-2016, 07:14 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Default AOA integrated in EFIS AFS3400, how to calibrate?
Hello,
I have the AFS AOA integrated in the EFIS, so the question is how to calibrate it there?
The manual only give information about the external AOA calibration, but not about the integrated one.
If anyone have the same setup than I, any help would be great.
Just prepare my brain to to it correct when in flight ...
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 05-12-2016, 07:17 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Hey Bugsy,
Don't stay unloaded for too long. Your engine still needs oil.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
