Old 05-09-2016, 12:36 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Originally Posted by Ed_Wischmeyer View Post
None in mine and the cell phone worked great.
Why don't we quit posting about healthy airplanes and see if anybody found cracks?
Ed
My guess is that no one who reads this sight and has done the inspection has found cracks, as soon as someone does we will probably hear about it.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 05-09-2016, 12:58 PM
It's reassuring to hear about all the RVs with NO cracks! Keep posting please!
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 05-09-2016, 01:40 PM
BASE1127 BASE1127 is offline
800hr RV-4 No cracks found.
Eric
RV-4
Senior Parachute Rigger
Old 05-09-2016, 01:49 PM
kkmarshall kkmarshall is offline
RV10
667 hrs
SB completed,no cracks.
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
Old 05-09-2016, 01:50 PM
PRE911 PRE911 is offline
Default Relevance of Models with cracks
I specifically haven't mentioned the models cracks were found because it really isn't relevant.
I don't want that info to bias anyone's thinking regarding any specific model.
I will say that of the three previously noted, they were not all the same model.
This can effect all models equally so all should be inspected.
BTW, this is also why I think a poll of inspection results is of no value other than to erroneously make some people think that one model is more or less likely develop a crack. The only model with a lower likelihood is the RV-6 because of the stub rib that is associated with hinge bracket attachment.
Dear Scott,
With all due respect I disagree with the holding back of information on what models, what airframe time, how they are flown if known (light aerobatics, aerobatic team, or little old person, notice I did not say lady, back and forth for groceries and church only on Sundays)
I am a 1st time RV-14a builder, and will soon be ready to fly. As with all other builders I have much time, money, energy, mental joy, immense satisfaction, as well as some stress invested into my project.
I would like to have all of the information about what may affect my project as it is available. I believe nothing should be held back from us builders.
Again I ALWAYS respect your opinions your guidance and your advice.
Please reconsider,
Thank you,
Rich
Building RV-14A. #140061
RV 14A N2261 flying as of 7/22/16
KDVO Novato, Ca.
Rich
Old 05-09-2016, 02:12 PM
awmuhs's Avatar
awmuhs awmuhs is offline
Default RV10 SB inspection
I was able to get the aft side of the inspection done using a boroscope. It is tight but you are able to get in to see the rivets in question without removing the aileron.
My 10 with 250 hours and my 6A with 1500 hours were both crack free
Alan Muhs
Tucson, Arizona
Dues overpaid July 2020
RV12iS Southern Arizona Teen Aviation: #1 airplane sold, #2 airplane working on engine/finish kit, #3 airplane tail kit finished.
RV10 flying since July 2014- 700 hrs as of July 2020
RV6A sold after 500 hours of flying
Old 05-09-2016, 02:14 PM
RV6_flyer's Avatar
No cracks found. 3,122.4 hobbs hours on RV-6 since first flight.
Spent more time trying to get a good smart phone photo than I did opening, inspecting, and closing.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Last edited by RV6_flyer : 05-09-2016 at 02:15 PM. Reason: added info about cell phone
Old 05-09-2016, 02:37 PM
gator gator is offline
Default No cracks
RV-8, built 2009, 900hrs. No cracks found
Old 05-09-2016, 03:26 PM
flyvans.com flyvans.com is offline
dear scott,
i have mainly three points to make, it's not the first time i struggle with some detailed but important aspects of a Van's SB. sorry if it is a little bit of a rant, but i do appreciate the company putting out SBs (and we are very happy customers / van's campers).
1. the world and your market consists of a bit more than just the u.s. and its particular aviation / regulatory system. so, whereas you may look at kit producers' SBs quite lightly/non-bindingly, this may not be the case elsewhere and (even partial/temporary) non-compliance can land you in hot water / has the potential to undeniably ground an aircraft. so please try to better strike a balance between maximum safety and still being able to operate/remaining in compliance practically.
2. the "before further flight" clause implies an ultra-immediate safety of flight issue, which appears to be actually much more of a longer term / high-time / ageing aircraft concern. let's say i owned a -10 (we have a -7A) and would be on a holiday trip through Europe, such as on a Greek island, planning to be back home only a few days later. Van's would just have significantly ruined my vacation, having to remove and reinstall ailerons abroad, lacking tools and proper work environment for what appears to be an extremely remote risk to my particular airplane. in fact, the risk introduced by messing around primary flight controls under sub-optimal circumstances is probably umpteen times higher. by the description of how this SB came about, chances of actually shedding an aileron in the next hour on a low-time aircraft are practically zero (as the thousands of higher time aircraft with, what must be a huge spread in build quality in the field have proven, as well)
i'm all for safety and distributing info as openly as possible, but if that leads to CYA blanket emergency-AD-like soundbites such as this, nobody gains anything (other than probably the lawyer that advised). at a minimum there should have been a compliance period "within the next 20 hrs" or a relaxation based on operating hours or so. certainly something risk/data driven. even the A380 had wing rib cracks but was kept flying throughout.
3. i also dislike the "backdating" of the SB in the title by multiple months from publication date. this could cause nasty questions during an airworthiness review, having operated after "the date" without having been "compliant".
please take this as a constructive input and into account when producing further SBs (hope not too many pop up)...
kind regards,
Bernie
p.s. AMC (acceptable means of compliance) would also benefit if some things could be a bit more openly formulated / less prescriptive / more suggestive / as examples. the clear instruction to remove paint in SB14-01-31 is such an unpractical if not impossible example.
Bernie Daenzer, Alex Lichtensteiger
www.flyvans.com
RV-7A
S/N 72072, Flying!
HB-YMT (Switzerland)
Old 05-09-2016, 03:30 PM
rvbuilder2002's Avatar
Originally Posted by PRE911 View Post
Dear Scott,
I would like to have ALL of the information about what may affect my project as it is available. And I mean every single detail. Absolutly nothing should be held back from us builders, ever.
Please reconsider,
Thanks you,
Rich
Rich,
I understand your viewpoint with a brand new airplane that is close to flying, but if I had said that one of the three was an RV-14, would it change what you should /would do?
Probably not. At least it shouldn't.
Van's has been transparent about this discovery (as well as others), and has recommended that everyone watch this location on the rear wing spars.
Keep in mind that after initial inspection, if no cracks are found, recurrent inspection is only required at each yearly condition inspection..... Regardless of hours flown.
That shows that it is not expected that cracks will develop or grow in size quickly.... if they happen at all.
This type of age /cycles related fatigue crack requires a lot of flight hrs to occur so if it makes you feel better I will say that none of the 3 airplanes was an RV-14. Does that mean RV-14's are immune to cracks in this location?
No.
That is why it is included in the SB for doing recurrent inspections.
Scott McDaniels
Hubbard, Oregon
