Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 05-07-2016, 12:59 PM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default Garmin GTN-650 GPS message
Is there a way to clear a message on my GTN-650 GPS that I believe may be a false message caused by my buffoonery? While taxing out I got a CO detect warning on my Flight Data Systems GD-40 CO detector. I had just changed the oil and could smell oil burning off the exhaust pipes (I thought I cleaned them but will do a better job next time). In a flash of knuckle-headed genius, I cycled my avionics switch off then back on in about a second. I wanted to reset the CO detector to determine if it was a real or false alarm. What I managed to do is screw up my GTN 650 GPS. I lost wind readouts and closest airports for that leg, and got a message ?GTN 650 needs service?. On all subsequent flight those functions returned but I still have the message. Is there a way to reset the message to see if it will stay off? If the message returns I will send it in for a checkout.
Thank you
Bob
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
Old 05-07-2016, 01:58 PM
Walt's Avatar
Walt Walt is offline
Go into the setup page (hold home while powering up) then:
GTN Diagnostics
Error Log
Clear the errors and see if that doesn't take care of it.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-08-2016, 07:18 AM
bobmarkert's Avatar
Default Thanks
Thank you I'll try that next time at the hangar
Bob Markert
Littleton, CO KBJC
2019 dues paid
