05-07-2016, 07:41 AM
New fuel tank test failure.....suggestions?
Of course I couldn't have the same luck as with the first tank. As you can see there is a leak at the corner coming out from the rear baffle. Any suggestions on the easiest fix? It is on the outboard end so no access holes.
[IMG]  [/IMG]
05-07-2016, 08:21 AM
If it is the bottom outboard corner it can be fixed working through the fuel filler hole.
Scott McDaniels
Hubbard, Oregon
05-07-2016, 09:18 AM
Wow, I was so disgusted at my leak I didn't even think about the filler hole. I immediately thought rivets were going to have to come out. Would you recommend just putting some proseal on a long stick and smothering the corner and general area with it? Thanks a lot!!!!!
05-07-2016, 09:40 AM
You are not alone Dave. It's a bit of frustration for sure but fixable.
05-07-2016, 10:40 PM
I have done one leak repair in the outboard bottom corner by working through the filler hole using a semkit cartridge with an clear vinyl hose clamped to the nozzle as an extension. You can tape the hose to a dowel and use that to apply sealant along the seams near the corner.
Then use a tong depressor (or something of similar radius) taped to a long stick to work the sealant into a radiused fillet (you may have to adjust it a couple times as you do the different seams).
Scott McDaniels
Hubbard, Oregon
05-08-2016, 05:16 AM
Dan Horton
RV-8 SS
Barrett IO-390
05-08-2016, 05:43 AM
The plates with holes drilled and appropriate rivets are available from Vans.
Been there, done that trying to fix quick built tanks.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
05-08-2016, 08:39 AM
I have had success on another type of aircraft using a vacuum and sucking Proseal into the leak.
Attach a shop type vacuum cleaner hose to the fuel filler. Pull a vacuum on the tank and clean the area with acetone letting the acetone suck into the tank. Then thin Proseal and paint it on the outside. If you are successful it will be sucked into the joint. It is obvious if it is working.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
05-08-2016, 10:07 AM
Same leak test failure here on one of my tanks. Mixed up a little proseal, got a long stick, and made what seemed like an awful looking, but perfectly functional, fillet seal in the corner through the fuel filler.
Kurt W.
RV9A
FLYING!!!
05-08-2016, 10:56 AM
I will second, or is that third, Dan's comment. After several years worth of battles with leaks I just could not stop, I cringed at the idea of cutting big holes in the rear baffle. I finally bit the bullet and did the big cut in all five bays. It was the best decision I could have made. I only wish I had done it sooner. It sounds scary and even a bit rediculous to cut a great big hole to fix a tiny leak but it really turned out to be the best choice for me. It really was an easy fix. So easy I did it twice in two months on the same tank (a long story). Vans has a kit just for this. Call them and order it. You wont regret doing so.
