Old 12-28-2006, 10:58 AM
kentb's Avatar
kentb kentb is offline
Default So the pen is mighter, but...
While doing my flight testing and collecting flight preformance number at 12,000 ft, I noticed this black substance all over my hand and paper that I was righting number onto.
My pen had reach an altitude that caused it to leak and made a mess. After cleaning up and looking into my flight bag I found my other pen was ok to use.
Don't know how high that one would be good for.
So now to the question for you high flyers. What kind of pen should I get that would be good upto 24,000 ft, if I ever get there.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 12-28-2006, 11:04 AM
jcoloccia jcoloccia is offline
I use old school and/or mechanical pencils. I never seem to have luck with pens in airplanes. They either don't work, I loose the cap or they leak. For me it has nothing to do with altitude...I just have bad pen karma, or something.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 12-28-2006, 11:11 AM
walter's Avatar
walter walter is offline
http://www.spacepen.com/Public/Home/index.cfm
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 12-28-2006, 11:37 AM
terrykohler terrykohler is offline
Kent:
From your comment, "if I ever get up there" I take it that you have not previously flown at flight levels. First, unless your A/C is turbo charged, I suspect that it won't reach FL240. Second, from 18,000 to FL600 is class A airspace and you must be instrument rated, operating under an IFR flight plan, controlled directly by ATC and have a transponder. VFR is not allowed. Altimeter is set to 29.92 only. Sorry if I'm telling you something you already know. FYI, I believe Sporty's sells pens that will perform at altitudes, or you can always go with a pencil (my personal choice after a number of bad pen experiences).
If memory serves me correctly (POH is in A/C) the service ceiling on my 9A is 19,000. You can get a great deal of performance information (14 page report) on Van's own 9A by going to:
www.cafefoundation.org
Happy flying!
Terry
Old 12-28-2006, 11:42 AM
Jamie's Avatar
Jamie Jamie is offline
Van's specs the RV-7/7A at between 21,000 ft and 25,500 ft according to engine. You don't need a turbocharger to get up there...just ATC clearance, an oxygen bottle, a mask and a warm jacket.
Old 12-28-2006, 11:44 AM
gorbak gorbak is offline
Default Russians Figured It Out
I once read a story of how the Space Engineers and private consultants for NASA spent millions of $$ working on a pen for space. You know, one that would not leak, break, fail, or fall apart. They did nearly perfect one style that literally cost $$millions.
The Russions used (and probably still do today) ....a number 2 pencil.
Cost? About .07 cents (US).
Pat Garboden
Old 12-28-2006, 12:04 PM
Ironflight's Avatar
VAF Moderator / Line Boy
My flight jackets, flight suits, and knee boards all have pencils in them.....
Regarding writing utensils in space, it's true that the "Space Pen" cost a lot to develop, but as I understand it, this was all done under private initiative - and THEN the government paid by the pen....but today, we pretty much have pencils everywhere. And, amazingly enough, they are pretty much standard-issue government mechanical pencils with a little velcro wrapped around them. Probably came out of the stock room cabinet.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-28-2006, 12:34 PM
Kent/Jamie:
Likely an RV7, F/I 360 with CS prop will produce a single pilot service ceiling above 25,500 (keep in mind this is not a legal FL). Van's numbers, while based on testing of their own A/C, are pretty accurate for all permutations. However, stall speeds, rate of climb, service ceiling, etc. will all be based on your own flight testing of your AC. Unfortunately for me, my normally aspirated, FP 9A came close to 19,000 with ony me on board - my next plan is to try one of those wonder diets that suggest 60 pounds in 60 days.
Terry
Old 12-28-2006, 03:22 PM
Bruce's Avatar
Bruce Bruce is offline
Default Grease Pencils
Kent,
Mechanical pencils and grease pencils on plexi nav boards or if you are in a hurry just right it on the canopy. Will wipe off. Saves on the stains and looking for something to write on.
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 12-28-2006, 04:08 PM
kentb's Avatar
Van's number for the 9A is 24,500 ft for solo and 18,500 at gross.
I don't have an O2 system yet, but will at sometime and I can get the IFR clearance, but won't want to go up high if there were clouds up there.
I am just so use to using pens that I prefer not to switch to pencils.
It shouldn't take much for a pen to work. We are not talking about lack of gravity, only air pressure equalization.
I think that the problem with my pen was that there was some trapped air in it somewhere that expanded and forced the ink out on to my hand.
Kent
Kent Byerley
Canby, Or
