Old 05-03-2016, 03:28 PM
Bruce Eddy Bruce Eddy is offline
Default Transceiver and intercom
I have a Micoair Transceiver (M760) it is the "P" version. This version has a built in intercom.
My question is this. I have seen several panels that are using these small transceivers (microair, MGL, Funke, etc.) and in several cases I have noticed that they are also using a stand alone separate intercom. I am wondering why they are not just using the built in intercom? Pros and Cons?
Bruce
Old 05-03-2016, 03:34 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Cant answer for other folks, but I do know a buddy who installed an intercom specifically for the aux inputs it offered.
By the way, in case I missed you earlier, Welcome to VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-03-2016, 03:35 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
There is no reason not to. I flew for several years using the GX-60 intercom function. It worked just fine. When you add other stuff this becomes limiting, like a second radio, nav receiver, audio input from the EFIS, music inputs and such. You can do some of this with switches, but then you start going toward a Rube Goldberg design.
A nice compromise is the very inexpensive Dynon audio panel.
Carl
Old 05-05-2016, 07:40 AM
Thank you for the input guys. I will do some more research on this. I will be using GRT sport EFIS so I can see using the input for that and music.
Thanks again.
Bruce
Old 05-06-2016, 07:13 PM
mscheuer's Avatar
mscheuer mscheuer is offline
Default PM3000A
Thanks again.
Bruce
Hi Bruce, just like to make note that the PM3000A is our stereo intercom that has two unswitched/unmuted inputs.
Mark Scheuer
PS Engineering, Inc.
VAF Advertiser
