You are right. If you are mounting the valve from below a mounting plate or whatever then yes this is an option to have nutplates on the valve.
I installed the selector valve from above so I put nutplates onto the underlying structure.
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
