Originally Posted by andrew phillips
I ran off the bucking bar (plate) when back riveting the stiffeners to the elevator. Now there is a small raised dent on the exterior of the skin. Can this be fixed? Do I have to remove the sifener and happer it out? Should I just get a new skin?
Lots of builders ding their empennage in a number of ways. And then many of them ask the forums if they should get a new part or just move on.
The people who replace parts because they're aiming for excellence rarely respond to this type of enquiry. On the other hand the "close-enough-is good-enough crowd" are always keen to chime in with the usual typical advice of "move on" or "you'll do worse before you're finished". They've obviously settled for mediocrity or less and they'd like you to do the same.
My advice is get a new skin and a few stiffeners. The price is negligable and you might feel better building a plane to the very best of your capabilities.
