Old 04-30-2016, 08:55 AM
Deweyclawson Deweyclawson is offline
Default Thousand word antenna installation
Does anyone have one of these antennas?
I am trying to figure out how to mount this in my RV6A wingtip but I don't think I know all that I should have been able to figure out from the directions.
A picture would be worth a thousand words.
Dewey Clawson
Super Sabre Society
2012 RV10; 1993 RV6A; 1947 Cessna 140, in progress
2019 dues exempt but paid anyhow
F100, A7D, A10, F16,
Fokker, Boeing, McDonnell-Douglas
Old 04-30-2016, 10:54 AM
nilberg nilberg is offline
That looks like a Archer antenna to me. If you google "Archer antenna installation" you will find multiple builders documenting their install. Mostly actually from this unbelievable useful forum.
It also looks like the COM version. Builder reports variable result with using the wingtip for comms, VOR versions seem to be more successful.
Old 04-30-2016, 12:03 PM
rv7charlie rv7charlie is offline
Default one version
http://www.vansairforce.net/articles...or_antenna.htm
Old 04-30-2016, 02:37 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
I have that antenna in my rh wing tip. Works amazing. I have it connected to my narco nav 122. Vor/gs/marker beacon all in one. Best money spent.
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 04-30-2016, 02:44 PM
Jesse's Avatar
Jesse Jesse is offline
I rivet it to a piece of aluminum angle and put 2-3 nut plates on the end rib to hold it in place then out some edge protector so it doesn't chafe inside the wingtip and hook the center conductor to the short piece of isolated aluminum and the shield to the main body. This allows me to connect the antenna with the wingtip off
Jesse Saint
Old 04-30-2016, 04:25 PM
Okay, the label says "com". Is that what you are going to use it for? Most people report it only works 'fair' because com needs vertical polarization. Best you can do: attach the top (in your photo) horizontal piece electrically to the outboard rib (usually by riveting the tip attach nutplates under it). If on bottom of rib, bend the leg with the label on it up as much as the wingtip allows. vice versa if riveted to the top of the rib. The long piece at the bottom now rests against the tip. Fiberglass in place. You want to get the piece with the label on it as vertical as possible.
Old 05-01-2016, 05:29 AM
Thanks for all the help.
It is a Com antenna. I searched all the suggested sources and found a total of one pic of the com ant. installed. It seems that few of these are used as com antennas unless the plane has a vertical tail suitable for mounting.
I was able to figure out which pieces are which. The instructions are not clear on top, bottom, radiating element, etc.
I am going to install it in the right wing tip and I already have a bent whip on the bottom fuselage. After I get the avionics install done, I am going to add com 1/2 comparisons to my flt test profiles. Comm 1 and 2 are both VAL 2000 radios so the difference will be only the ant. install.
Dewey Clawson
Super Sabre Society
Old 05-01-2016, 07:33 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Tried it --- did not work well
In the RV-10 ----- had an external for Comm 1, but tried the Archer for Comm 2, as well as a Archer Nav. The Nav worked only "OK", but the comm was bad enough we installed another external whip fro Comm 2.
R.
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 05-01-2016, 09:19 AM
For more discussion and PICTURES look at post titled "antenna tuning" dated 12-1-2013. Second page.
This is a -10 wingtip, larger than a -6. The fore-aft location, and mounting the ground piece to the top of the rib (via the tip attach screws and top of the wing (make sure to remove paint from under the screws!)) was chosen to maximize the vertical component of the antenna where the maximum current is carried). As I said, not as good as an external whip, but okay, for me, for ATIS/#2 com.
Old 05-01-2016, 09:33 AM
BillL BillL is offline
http://www.vansairforce.com/communit...d.php?t=107189
or Click here and limit to IMAGES
Bill
RV-7
Lord Kelvin:
