Old 04-28-2016, 08:22 AM
WISC WISC is offline
Default Buying an aircraft in Phase1
What are the issues with buying an aircraft that has just started Phase 1. The aircraft is not in my local area.
1. Which FSDO issues the ferry permit?
2. What are the odds of actually getting a ferry permit?
3. Do I need a new set of operating limitations and start phase 1 all over?
4. I am sure there are many other concerns and I appreciate your insight.
RV-7A
RV-6A- Sold due to military move
Old 04-28-2016, 08:33 AM
If seller is motivated he will complete phase one testing.
What is the big rush? Anyone can fly off the requirements.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 04-28-2016, 09:01 AM
Guy lost his medical.
I would fly it off if that is legal but the airplane is not local.
I can't speak as to why owner hasn't had someone else fly it off. I need to get a ferry permit to move it and change the ops limit as a minimum is my understanding.
RV-7A
Old 04-28-2016, 10:14 AM
Aggie78 Aggie78 is offline
Default Webinars
EAA had a couple of webinars you might be interested in.
Here's one by Mike Busch on Ferry Permits:
http://eaavideo.org/video.aspx?v=4040527226001
And another one here on buying and selling E-AB aircraft here:
http://eaavideo.org/video.aspx?v=3096724434001
I seem to recall in this last one, the presenter either discussed or was asked about getting a ferry permit while in Phase I....his belief was the FAA would be disinclined to issue one, but you can always ask.
Rob S.
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
VAF Monthly Donor
Old 04-28-2016, 10:25 AM
Mel's Avatar
Mel Mel is offline
FSDO where the aircraft is presently located.
Slim. Depending on the distance.
Yes & No. You won't need to restart phase I, but you will need amended op lims to change test area.
See above.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-28-2016, 10:36 AM
rolivi's Avatar
rolivi rolivi is offline
How many hours does it need to clear Phase1? Seems like you could factor the cost of the trip into your pricing and go have fun flying it off.
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
Old 04-28-2016, 11:01 AM
ty1295 ty1295 is offline
No expert by any means, but I believe any pilot can fly off the time, owner or not.
I would also think, the easiest would be to fly it off at location and avoid a bunch of hoops and paperwork. Even if that meant traveling for week, or heading on weekends as available to make that happen maybe even recruit some helpers.
Jeff Scott
RV9A First Flight 9/30/19
Old 04-28-2016, 11:37 AM
rv7charlie rv7charlie is offline
I've heard rumors of people getting ferry permits for Phase 1 planes, but don't know of any personally. I'd bet that it's highly dependent on the FSDO where the plane is located.
What worked for me about 20 years ago was to pull the wings & trailer it home. After I reassembled it on my home field, the local FSDO reissued the oplims with a local test area. It's been a long time, but IIRC, they didn't even look at the plane. I just took the old oplims to them & picked up the new ones.
Charlie
Old 04-28-2016, 01:12 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
FWIW, phase 1 isn't for just flying time off.
It's for flight testing.
Can be 25 hrs with a tested prop/engine combo or 40 hours.
I would suggest making arrangements for someone to complete the phase 1.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 04-28-2016, 01:47 PM
deek deek is offline
I asked for and was granted a ferry permit to fly a Lancair 320 in Phase 1 from Spokane to 8S1 - about 150nm. No issues, no restrictions.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
