Old 04-27-2016, 11:24 AM
Bradw04 Bradw04 is offline
Post Pilot Height Help..
Hey guys, new here... Had a question.. I'm considering looking at an 6,7, or 8 to buy within the year.. I'm 6'5 which if any would fit me headroom and legroom wise the best? I'd really like to go with the 6 or 7 but I've heard they are a tight fit for anyone over 6' really.... Any help is appreciated thanks...
Old 04-27-2016, 12:02 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Probably OK
I am 6' 3-1/2" with most of my height in my torso (I have 32" inseam pants) - so I usually have a headroom problem in cars, etc.
In my -7 slider, I have no problems though. I use Classic Aero Design's Aviator seats with no booster cushions and the seatback set in the aft-most hinge position. The rudder bar is mounted in the forward-most position specified in the plans. I have used a 1" booster cushion before as a test, and I still fit (although the headroom was a minimum).
YMMV
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 04-27-2016, 12:12 PM
flyboy1963's Avatar
Default unofficial welcome!
Hi Brad, great question.
I think you have to go sit in a few, and see what the options are.
many guys say they have no problem, I am 5'10" and use minimal cushions, but bang my head often...so go figure. ( am not a giraffe)
also, check out the 'almost a -14' mod at antisplat aero....it creates a more reclining position, thus more headroom.
https://www.youtube.com/watch?v=LMJKmUeMJHM
...or just go order an RV-14, I don't think you can possibly regret that!!!!
( I have no affiliation with ASA, just a fan!)
P.S. I have a -9a for sale, we'll make it fit you!!!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 04-27-2016, 12:16 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
I'm 6'5" with a 34" inseam. My -6A is plenty comfortable, and I've done quite a few 4+ hour legs without issue. There's enough headroom for a headset or HGU-55 helmet, and pulling the back seat cushion provides enough room to comfortably wear a backpack chute when appropriate.
While it's true that the 7/9 have more torso height, I'm not terribly certain how significant it is as my hangar mate's -7 is tight for me. I speculate that builder choices, such as seat cushions, canopy placement, and possibly other factors have a bigger effect. You'll want to check the actual aircraft for fit because of this variability.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 04-27-2016, 12:29 PM
rolivi's Avatar
rolivi rolivi is offline
Welcome!
You'll also want to consider Halo's or Clarity's to save that space where the headpad would be on most headsets.
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
Old 04-27-2016, 01:02 PM
Thanks for the replies guys.... I have been in search of a -6 or -7 close by but cannot find anyone near me to try it on for size... I'm located in northern Missouri if anyone is within a resonable distance and doesn't mind my big self climbing in your plane... I'm also pretty set on either the -6 -7 or -8s and tail dragger all the way! Lol
Old 04-27-2016, 09:48 PM
gerrychuck gerrychuck is offline
I'm over 6'3" with very long legs, and fly a 6A slider. I fit ok with the "normal" setup, although my left arm/elbow was a bit cramped, and I tended to wear very thin-soled shoes to give myself a bit more legroom. However, I installed AntiSplat's "Almost an RV 14" mod and it completely transformed the fit of the plane; now I have no issues whatsoever with elbow room, leg room, or head room, and the slightly more reclined sitting position is MUCH more comfortable on the low back as well. I think you would fit fine in a 6 or 7 with this mod.
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
Old 04-27-2016, 10:22 PM
bpattonsoa bpattonsoa is offline
Dan and I have near the same dimensions, 6' 4" with a 32" inseam. In my -6A I used a thin, 1" seat to get enough headroom and built it with the rudder pedals as far forward as possible. It was Ok, but tight. Almost got knocked out in some sudden turbulence crossing a ridge.
I put the "almost a 14" modification in it and it became wonderful. The -10 is a different story, a Caddy vrs. a VW.
Try and find one for size especially one that has the mod. Mine is in Oregon and for sale soon.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
Old 04-28-2016, 07:10 PM
Any reviews on the -8 for tall guys??
Old 04-28-2016, 11:31 PM
skylor's Avatar
skylor skylor is offline
Default RV-8
I'm 6,3"' 240#, 34" inseam, and broad shouldered. I have 500 hours in my -8 which I did not configure with the tall pilot option, and it is extremely comfortable for me even when carrying a large passenger . A recent ride as a passenger in a -6 reaffirmed my decision to go with the -8 since I did not have much shoulder room, head room or knee room.
Skylor
