Old 04-27-2016, 10:42 AM
TCONROY's Avatar
TCONROY TCONROY is offline
Default Mag Timing
I am performing the first condition inspection on our RV-7 with an IO-360-M1B and did a timing test using a "buzz box". I read the directions and believe I performed the test correctly which shows both mags set to approx 28-ish degrees. Could this be correct? Both mags off by exactly the same amount? Should I loosen the hold down nuts and adjust to 25 degrees accordingly?
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 04-27-2016, 11:27 AM
Make sure you have taken any backlash out by moving the prop past 0 deg to snap the impulse couplings, if any; turn back about 35 deg; then move in usual prop rotation direction. If they are still at 28 then yes, move forward to 25, loosen the mag hold down nuts and adjust.
WA85 WA85 is offline
Based upon the picture, yes it looks like the R and L magnetos are timed at about 28 deg BTDC. New magnetos, with new points and cam actuators tend have a bit of timing drift over the first 25 to 50 hrs due the contact areas wearing in. Pretty normal. Some magneto overhaul facilities put a tag on the magneto that states to check the timing after the first 25 hrs. Adjustment is easy, loosen the two hold down nuts for the magneto and adjust as needed. I always do the RH non impulse first, then the LH with impulse, but that is my opinion. Loosen the nuts just enough to turn the magneto, but not so loose that the drive gears get sloppy meshing, which affects the timing adjustment. Re-torqueing the nuts can change the gear mesh / timing slightly, always double check. Remember to take the gear lash out my turning the prop about 30 degs beyond the timing marks, then in direction of rotation to the timing marks.
Old 04-27-2016, 11:32 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Shouldn't you back into the proper setting to take out gear lash? I.e., pull the prop well past set point, release the impulse coupling if applicable, then rotate the shaft backward to the proper position?
Bryan
Houston
Old 04-27-2016, 11:38 AM
No. Approach 25 deg in the usual direction of prop rotation. If set going backwards, it may be off going forwards.
Old 04-27-2016, 12:02 PM
Low Pass's Avatar
Got it. Mag drive gear loads the same whether the pistons are driving the crank or the propeller.
Bryan
Houston
Old 04-27-2016, 03:20 PM
TCONROY's Avatar
Great, thank you for the feedback!
________
Airbus Pilot
N781TD
RV-7
Construction Log
Old 04-28-2016, 01:02 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Also be aware, recently supplied (say manufactured in 2014-15) points from Slick have been known to drift by a few degrees.
CASA, Champion and even the FAA seem to have their heads in the sand over SDR's issued by engine shops.
You may want to check this too as the internal timing may have changed.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 04-28-2016, 04:49 AM
vic syracuse vic syracuse is offline
Super Moderator
Default Check points manufacture date
David is right. Make sure you get a set of points manufactured late 2015 and you should be ok. The date code is stamped on the box.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
