Go Back   VAF Forums > Main > Safety
  #21
Old 05-03-2016, 10:03 AM
tomhanaway tomhanaway is offline
My aerosport IO-375 came with the updated dipstick. You might be able to contact them to purchase.
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
Old 05-11-2016, 12:58 PM
Berchmans Berchmans is offline
Default Complied
I picked up my replace stick today...it's about 3/8ths of an inch longer than the original and the markings have been move that corresponding difference. Wow, this seems like a tempest in a teapot as I must say I don't read mine that close when I pull it...needs to be off by a whole quart before I add...well, $167 later I hope Lycoming covers under warranty...
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2020
Old 05-11-2016, 07:43 PM
spatsch spatsch is offline
Do you think you could post a photo showing both of them side by side?
I think I am confused. If the new one is longer then the old one with the same spacing of the markings starting at the bottom the old one should show a lower oil level indication then there actually exists. That would be a safe but potentially wasteful condition. However, the SB says the old one gives a higher oil level reading then there actually exists which is an unsafe condition so I am confused.
Would also be good to know how the warranty claim works out for you. I certainly won't spend 167$ for a new dip stick out of my pocket if I can just recalibrate the old one at my next oil change for free... . After all mandatory SBs have little legal meaning for an experimental engine... .
Oliver
Oliver Spatscheck
RV-8
N-2EQ
http://www.spatscheck.com/oliver
Old 05-12-2016, 06:06 AM
BillL BillL is offline
Default What if I do nothing? i.e. do not comply.
The SB says "5 quarts (5 liters)" like that is the same. Granted .28qt would seem like a minor difference, but 3/8" is probably less than that.
So - what happens with my new M1B, if I do nothing with this? Not to the engine, that is not relevant - it is the paperwork that counts to lawyers, FAA, and insurance.
Bill
RV-7
Lord Kelvin:
Old 05-12-2016, 06:45 PM
rzbill's Avatar
rzbill rzbill is offline
I think I may just stamp "ish" next to each of the numbers on my dipstick......
Previous post about the new stick being longer has really got me curious.
Bill Pendergrass
ME/AE '82
Old 05-13-2016, 05:39 AM
grubbat's Avatar
grubbat grubbat is offline
Default Twin Comanche Oil Level has been off for 50 years
My 50 year old Twin Comanche has identical dipsticks on the Lycoming IO-320-C1A engines. However, the engines are not level due to the dihedral of the wings. What this means is that the left engine dipstick will indicate 1 qt more than actual and the right engine dipstick will indicate 1 qt less than actual. Its been this way for 50 years without a SB or AD.
Those of us with tail-draggers will also have an indication issue when parked no matter what dipstick you use. Sounds like this SB was issued without a lot of thought of reality or actual use. Maybe there is a market for custom made dip sticks for the newbie who has no knowledge of these matters. Who knows.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 05-13-2016, 07:22 AM
airguy's Avatar
airguy airguy is offline
When I changed the sump on my IO360 from Lyc standard to Superior forward facing, I simply made the *assumption* that the sump levels might be different, buffed out the marks on the dipstick and remarked it by pouring in a quart at a time. The new marks are almost exactly on top of the old ones...
Old 05-14-2016, 11:22 AM
Lux Wrangler Lux Wrangler is offline
Default Much can be ascertained by finding out
I think I am confused. If the new one is longer then the old one with the same spacing of the markings starting at the bottom the old one should show a lower oil level indication then there actually exists. That would be a safe but potentially wasteful condition. However, the SB says the old one gives a higher oil level reading then there actually exists which is an unsafe condition so I am confused. - Oliver
The dip stick is longer, but the 4 quart mark is higher up than before.
Jim Peck
San Francisco Bay Area
RV-7
Old 05-28-2016, 06:52 PM
rzbill's Avatar
I did an oil change on my M1B today and the above note agrees with what I read on the "bad" 16783-18 dipstick. I put in 4 quarts and the oil level read well above the 4Q mark (I did not measure but it looked like 3/8 to 1/2"). Put in 5 quarts and did measure it. The level showed 3/8" higher than the midpoint between the 4Q and 6Q mark. Hmmm, does that mean I have been slack for 4 years? Not so fast, I don't run that low plus..........
I put in another quart to make it six and what do you know but the dipstick read 6Q dead on.
The upshot is, now I know. I may change the stick if I get around to it but it is no emergency for me personally. YMMV.
On a separate note I installed a Fumoto 202 oil drain valve today. No more fooling with the pipe plug. Only took 10 oil changes to make me get around to it.
Bill Pendergrass
ME/AE '82
Old 05-28-2016, 07:28 PM
Interesting, data usually is. On the off-topic: I installed the same valve with the nipple for attaching a hose. Will you be safety wiring the handle? How?
Bill
RV-7
Lord Kelvin:
