Old 04-26-2016, 10:12 PM
SMO's Avatar
SMO SMO is offline
Default Glide Ratio Weirdness
I have never satisfactorily determined the "Best Glide" speed for my F1 EVO Rocket. I have now done a few flights trying to pinpoint this, and while I think I need to change my process a bit in order to get more accurate, I have discovered a weird anomaly and I wonder if others have seen something similar. The following graph shows the data points I have determined in 3 different flights on different days. The thing I think is weird is that every flight shows that at 105 knots the glide ratio is worse than the preceding or subsequent speed.
Anybody have an explanation for such a result?
The method I have been using: Determine the number of seconds it takes to glide from 3500' to 3000' at a constant IAS (+-1 knot). I get this from the data log of my G3X. I then convert the speed to "feet/minute forward" (knots * 101.269) and descent to "feet/minute vertical" (60/(seconds * 2) * 1000). Dividing feet/minute forward by feet/minute vertical provides the glide ratio. The speed with the best glide ratio is the best glide speed.
The problem I have with this method is that I need a more granular measure of time, or I need to increase the glide distance to 1500 or 2000 feet. However I don't believe making these changes will impact the seemingly repeatable event that shows 105 knots having a poor glide ratio.
I also understand that flying on different days with different weights, temperatures and air densities will also give differing results, so I am not unduly concerned that each days flight has some differences.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 04-26-2016, 10:54 PM
logansc's Avatar
logansc logansc is offline
I don't have an answer Mark, but I can confirm that my sport wing Rocket seems to "give up" pretty quickly shortly after 100 knots as well. My testing was not as repeatable nor as precise as yours and also I didn't press the issue after the descent rate dropped off so obviously shortly after 100 knots. As a result, I did not pick up that things might improve again 5-10 knots faster. I was a bit surprised that (apparent) best glide was as high as it was, however.
Maybe one of the other technical guru's will chime in here, but I wouldn't be surprised to learn that this anomaly is related to prop drag somehow. You didn't specifically mention what you'd done with prop pitch during your testing (I'm assuming these were not actual engine out tests?)
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
Old 04-26-2016, 10:58 PM
SMO's Avatar
SMO SMO is offline
Oh yeah, should have mentioned - all glide tests done with prop all the way back (full coarse) for maximum glide.
Mark Olson
1987 RV-4 Sold
Old 04-26-2016, 11:18 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
I'd ping Steve Smith (scsmith on this forum), this is his area of specialty.
Looking at the data, I'd be tempted to suspect a leak in the static system used as an altitude and descent rate reference.
Thanks, Bob K.
Old 04-27-2016, 12:48 AM
PilotjohnS PilotjohnS is offline
Default Laminar flow trip
Last time I saw a curve like that was when Dick Johnson was doing sailplane testing. If I remember right, His cause was the laminar flow not tripping properly. He resolved it but photographing the laminar flow trip using dirty oil on the wings. And using a zig zag strip on the wings to trip the laminar flow. Maybe it is worth a flight with dirty oil and a GoPro to make sure the laminar flow is tripping properly. Dick Johnson wrote a whole series of articles on this subject and should be searchable.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2022, worth every penny
RV9A- Status:
95% done, 5% left to go
Structure 98% done (less gear and windscreen)
Electrical/Panel done
Firewall Forward 95% done (waiting on stuff to be done)
Fiberglass 15%
www.pilotjohnsrv9.blogspot.com
Old 04-27-2016, 06:57 AM
BillL BillL is offline
Intelligent thread. Here is a link about the deturbulators that solved the problem. Note that it was dubbed the Johnson Effect.
http://sinhatech.com/SinhaFCSD-Progr...07.asp#article
If someone could help with the physical description of these deturbulator tapes please do so. It looks like they do not protrude above the surface except a tiny bit. Are they like s tiny flapping film? I will be doing more searching, meanwhile.
Bill
RV-7
Old 04-27-2016, 08:28 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Try this:
With a good coat of wax on the wing, tape over the screw line that attaches the leading edge, and repeat the experiment. Could be that the screw line is tripping the flow locally, and it does not re-attach at that AOA/IAS.
If you find this to be the case, Rockblocker tape could be used to cover that screw line in a more permanent manner. I'd recommend the .020 thick stuff for that application.
Interesting experiment indeed!
Carry on!
Mark
Old 04-27-2016, 09:33 AM
erich weaver's Avatar
erich weaver erich weaver is online now
Default Real time glide ratio display
FYI, the garmin x96 series gps units can display glide ratio in real time on their data page. I would guess the newer units can do the same but I am not familiar with them.
Erich
Old 04-27-2016, 09:58 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Blake has the "rockblocker" tape on the Flyboy Accessories site.
http://www.flyboyaccessories.com/Pai...ilm-p/2301.htm
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 04-27-2016, 01:42 PM
SMO's Avatar
SMO SMO is offline
I'll try taping off the leading edge screws, retest, and provide an update.
Mark Olson
1987 RV-4 Sold
