  #11
Old 04-27-2016, 05:29 AM
BillL BillL is offline
Originally Posted by longranger View Post
I started my first project in 1998, an RV-4 empennage with 0.016 skins. I started out with the plate on my wood bench and had trouble with proud rivet heads. After moving the plate to the concrete floor, no more problems (except when I ran past the plate...).
Use a small powerful magnet from True Value to mark the end of the steel, or a red WakTack. I wish I had.
Bill
RV-7
Lord Kelvin:
Old 04-27-2016, 05:47 AM
bret's Avatar
bret bret is offline
like mentioned above, make your own BR plate, I made a 8X40" plate, be carful with a small one, you can easily do serious damage if you miss the plate and pull the trigger!
Old 04-27-2016, 08:27 AM
rmartingt's Avatar
Originally Posted by David Paule View Post
Interesting - that's the opposite of my own experience and on my RV-3 project, the surfaces are only .016.
I much prefer the results I get back-riveting.
Dave
I should clarify, I back riveted the stiffeners in the tanks and ailerons because conventional riveting wasn't practical for those (the ailerons are too thin and the tank too awkward without the ribs). But I never was super-happy with the results. I tried back-riveting the firewall stiffeners and it just didn't work well at all, plus it was awkward to set up. It was easier just to conventional rivet.
RV-7ER - finishing kit and systems installation
Old 04-27-2016, 10:31 AM
Capt_Riney Capt_Riney is offline
Smile
Thanks everyone for all the great advice!
Mark Rinehart
RV7 Quickbuilt kit
Old 04-28-2016, 03:54 PM
atalla atalla is offline
Blue scotch painters tape is working well for me.
Andrew Atalla
Red Seal Automotive Service Technician
Red Seal Heavy Duty Equipment Service Technician
Welder/Fabricator
Squamish BC CYSE
RV-7 Left Elevator in progress
Dues paid
