Old 04-28-2016, 11:04 AM
MikeyDale's Avatar
Originally Posted by beav View Post
When I had issues with fluctuating fuel flows, EI told me that the #1 cause was poor electrical connections. Despite having crimped on knife splices, I took them apart and simply soldered the wires together and covered with heat shrink. They have been rock solid and accurate ever since.
I think I'll give that a try! Thanks Jason.
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
Dues Paid
Old 06-11-2016, 07:30 AM
MikeyDale's Avatar
Thanks Jason! While doing my recent condition inspection, I removed the connectors and spliced and soldered the wires and it has apparently solved my problem.
Mike Hillger
Garden City, Texas
Dues Paid
Old 06-11-2016, 07:57 AM
BillL BillL is offline
Thanks for closing this out. That does it, I have been looking at those connectors, as I do other FWF stuff, they will get soldered! Another issue avoided.
Bill
RV-7
Lord Kelvin:
Old 06-11-2016, 08:04 AM
AltonD's Avatar
AltonD AltonD is offline
I ended up using d-sub pins separately and heat shrink. No problem since. Just ditch the shell and connector and plug pins into the other, heat shrink.
https://m.youtube.com/watch?v=f8DCvBV2V4M
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 07-02-2016, 08:17 PM
tomkk's Avatar
tomkk tomkk is offline
Default One more Red Cube failure
I started having a problem with intermittent zero fuel flow (good fuel pressure & engine ran fine) after about 140 hrs TT. Sometimes it would show zero fuel flow at engine start then jump up to normal flow after half an hour or so and remain normal thereafter.
I checked all the wiring and connections and didn't find any problems. I removed the unit and blew low pressure compressed air through it and could hear the wheel spinning inside.
Finally I just bit the bullet and bought and installed a new one and the problem disappeared. Everything normal.
Out of curiosity, I disassembled the old unit to see if I could see a problem. It's pretty simple inside and I didn't see anything that looked like it would cause a problem.
Interestingly, the new unit (from AS&S) came with three connectors, one for each wire, that I hadn't seen before. Each was a small sleeve with an allen screw in the middle. It's like a small butt splice except the wires overlap inside the sleeve and the allen screw is tightened to secure the splice. Seems pretty secure.
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 11-17-2019, 06:21 PM
Jake14 Jake14 is offline
Had the same problem after 300 hrs: gph drops intermittently to zero, fuel pres normal. Replaced the cube and all ok
added a larger stainless steel heat shield from ACS:
https://imgur.com/D494OMN
RV-14A flying 410 hrs
