Boost pump circuit protection location
Building an RV-14A , IO-390 with mechanical engine driven pump and backup electric boost pump. I had full intentions of mounting the circuit breaker directly in front of the pilot on the main electrical buss. But I cannot count past four and missed a breaker (should have installed four). Problem is now I have other switches/breakers with larger holes than the breaker I need to add. My first choice would be to move the boost pump to the fuse block I have mounted just below the panel just forward of the fuel valve that is in the tunnel (One of Van's RV-14's has a panel mounted at the same location) . I can see and access the fuses while flying easily.
I have the boost pump installed to the breaker now but need to steal this breaker for the flaps which I need to have quick access to in case of problem with runaway (I do have a flap controller installed but you never know).
My reasoning on moving the pump protection is there is still a switch on the stick to control it. It's a back up system that gets tested constantly so you would have to have both pumps fail at the same time in order to need to replace a fuse in an emergency, and it is still an option that would only take a few seconds to do.
What do you think, am I overthinking this or missing something?
Thanks Ron
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
